Old 02-20-2005, 06:33 PM   #1
1STtimePRo'71
1STtimePRo'71's Avatar
Temp. Sender
The tempeture gauge in my dash doesnt work. And I got a new temp. sender today but I cant find any info on it in my book. What's involved with switching these, and might this solve my problem?
-Cory
1967 2 Wheel Chevy
1STtimePRo'71 is offline   Reply With Quote
Old 02-20-2005, 07:11 PM   #2
Striker169
Car O'Holic
Striker169's Avatar
I was also wondering becuase I want to change mine out
Striker169 is offline   Reply With Quote
Old 02-20-2005, 09:41 PM   #3
chevy69er
Does anyone know where the best place to put the temp sender is?Im running in on the cylinder head but have also seen it in the intake manifold.
1969 C-20,383 stroker,sm465,custom long travel front suspension,4 wheel disc brakes,35" pro comps...mods under way include: 4x4 conversion,and custom bumpers.future mods include: gear vendors od unit,and relocation of fuel cell.
chevy69er is offline   Reply With Quote
Old 02-20-2005, 09:43 PM   #4
1STtimePRo'71
:hj:
-Cory
1967 2 Wheel Chevy
Old 02-20-2005, 09:50 PM   #5
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
It's easy. Just pull out your gauge cluster, then remove the metal back cover, and just remove the screws/nuts that hold the gauge to the printed circuit. Be careful because sometimes the printed circuit can get stuck to the nuts and it is easy to tear it when you try to remove the nut. On my truck I have the sending unit mounted in the water neck on the intake manifold, and it reads right in the middle of the gauge.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 02-20-2005, 11:37 PM   #6
Fred T
Cantankerous Geezer
Fred T's Avatar
Sending unit is real easy to replace. It's either in the side of the head between #1-3 cylinders or in the intake manifold near the thermostat housing. Simply unplug the wire and unscrew the sending unit. Put the new one in with either teflon tape or a non-hardening thread sealer with teflon on the threads. Then plug the wire back in.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 02-20-2005, 11:41 PM   #7
1STtimePRo'71
Thanks Fred T. Appreciate your help.
-Cory
1967 2 Wheel Chevy
Old 02-21-2005, 08:23 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If you're quick, there's no need to drain the coolant out of the engine. Just have the new one setting there with goop on it already and work quick.
Old 02-21-2005, 08:59 AM   #9
1STtimePRo'71
Thanks for the tip. Off hand anybody know what a 71 3/4 350 w/o ac would hold for coolant. Gallon wize?
-Cory
1967 2 Wheel Chevy
Thread Tools
Display Modes
