Old 02-21-2005, 01:12 AM   #1
soleeagle
soleeagle's Avatar
Disc Brake Conversion
I finally got around to putting my disk brakes on my 14 bolt FF. I was going to put it in the 83 but now I have decided to put it in the 91 burb I just got. This little project was alot less trouble than I thought it was going to be. I got the plans for the brackets off of e-bay but I modified them a little so they would be stronger and safer in my eyes. I made them at work and they were laser cut on our new Mazak laser.
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
Old 02-21-2005, 01:13 AM   #2
soleeagle
soleeagle's Avatar
More pics
Chuck
Old 02-21-2005, 04:54 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Thumbs up
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-21-2005, 11:45 AM   #4
Mudder
Mudder's Avatar
Does the rears have ebrakes?
Mudder is offline   Reply With Quote
Old 02-21-2005, 05:56 PM   #5
badphish
what were the calipers sourced off of?
badphish is offline   Reply With Quote
Old 02-21-2005, 08:40 PM   #6
454_72_4X4
454_72_4X4's Avatar
I've been wanting to do this conversion for years now! Looks good. How thick is the spacer between the caliper bracket and axle flange? If ya don't mind me askin'.
What are ya gonna use for a master cylinder/ prop valve?
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 02-22-2005, 12:09 AM   #7
drink2mny
drink2mny's Avatar
Very nice pics
Support The Board
drink2mny is offline   Reply With Quote
Old 02-22-2005, 12:16 AM   #8
soleeagle
soleeagle's Avatar
No the ebrake will have to be removed, but with the auto I wont need them any way. Indiana dosnt require you to use them.
Chuck
Old 02-22-2005, 12:19 AM   #9
soleeagle
soleeagle's Avatar
The calipers and rotors were sorced from a '75 3/4 ton. I just went to Auto Zone and asked for the parts to a '75 3/4 ton truck front and they put them on the counter, they are the same ones used on the front axle.
Chuck
Old 02-22-2005, 12:21 AM   #10
bigarmzz
bigarmzz's Avatar
man, you really ought to help out some of us and post some part numbers?
i'd love to do this mod someday
did you have to use another master cyclinder?
-bigarmzz-
bigarmzz is offline   Reply With Quote
Old 02-22-2005, 12:22 AM   #11
soleeagle
soleeagle's Avatar
The brackets are made out of 3/8 A36 steel and the spacers from 3/4 steel, The plans called for peices of pipe to be cut to 3/4 in length but I didnt think that they would be strong enough so I made my own spacers. I am just going to use the stock master cylinder and lines, I will be reroughting the lines on the axle to use rubber lines as on the front axle.
Chuck
Old 02-22-2005, 12:29 AM   #12
soleeagle
soleeagle's Avatar
-bigarmzz-
The Auto Zone Numbers I bought were:
2 @ 716779 5523 567 Brake Rotor $23.99 each
1 @ 095745 C503 Disk Brake Caliper $15.99
1 @ 095752 C502 Disk Brake Caliper $15.99
The number came from my receipt and they told me that that particular rotor is not going to be a stock item and when the supply is gone they will be gone. I am sure they will replace them with another brand.
Chuck
Old 02-22-2005, 12:51 AM   #13
bigarmzz
bigarmzz's Avatar
cool, this needs to be a sticky
do you have a link where you bought the plans off ebay?
i'd need them for a half ton though....12 bolt rear
do they give you the plans for the spacers as well?....how exactly did you modify your spacers?..
i'd have to take the plans to a local machine shop..
-bigarmzz-
Old 02-22-2005, 01:12 AM   #14
soleeagle
soleeagle's Avatar
-bigarmzz-
The plans for the 1/2 ton 10 and 12 bolts axles are alot more complex. I am planning on buying them also so I can convert my 85 over to disc brakes. Try this link it might work http://search.ebay.com/_W0QQfgtpZ1QQ...3aMEWAQ3aMESOI if not the seller was tt5t
I actually bid on one of them. If I get it I might make some deals to send out copies to board members for donations to the board, I will contact Liz about this if we get enough interest in it.
Chuck
Old 02-22-2005, 05:12 AM   #15
Mudder
Mudder's Avatar
My brakes where done with the original backing plate , rotors and calipers from the front. A notch has to be cut in the backing plate and holes drilled. There is also a spacer. I have the size for the spacer or I can get them. I have always had this info but noone has ever contacted me for it.
Old 02-22-2005, 09:51 AM   #16
drink2mny
drink2mny's Avatar
Oh come on Mudder... How do think I have a business.
I was the guy at your back axle taking measurements, you know in the parking lot at that store we all shop at....
Ok maybe not...
Nice article.
Support The Board
Old 02-22-2005, 11:39 AM   #17
Mudder
Mudder's Avatar
The guys that came up with this conversion got all the info from a article in one of the 4x4 mags. They used a magnifing glass to get the part numbers off the parts in the article. I thought that was pretty funny. The only thing this one lacks is the ebrake and it can be had but very expensive from what I have found. Myself I never use a ebrake with a auto, but someone using a standard would have to have something.
Oh, and I'm not trying to steal bussiness or the thread. The 14 bolt ff is pretty easy.
Old 02-22-2005, 12:01 PM   #18
454_72_4X4
454_72_4X4's Avatar
Yea, that's the way I want to do mine cause I've already got the backing plates and a set of calipers for cores when the time comes.
I know the holes have to be drilled in the backing plate but this is the first I've heard of a notch. What's the notch for?
Also if ya could, the thickness of the spacer would be appreciated.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 02-22-2005, 01:53 PM   #19
drink2mny
drink2mny's Avatar
Not to steal the thread.. But 454 72 4x4 I think I have a set of aluminum spacers from an older kit, before I went to work for blackbirds..
I was only going to ask 60. plus shipping.
If your interested, i can take a look for them.. I know mudder has seen them in previous for sale threads I have made..
There are alot of great websites for the 14 bolt conversion..
pirates4x4.com ck5.com and others...
I would however ask you guys to do what soleeagle did.. Use a thick spacer instead of the pipe spacers..
I have seen first hand the pipe spacers break and twist under a set of 39 boggers hard braking..
I would offer our kits to you guys, but we don't just sell the brackets..
shakerbuilt.com and some guys on ebay sell them..
Pretty good prices too. If you use shakerbuilt. please tell him blackbirds sent ya..
Support The Board
Old 02-22-2005, 02:17 PM   #20
454_72_4X4
454_72_4X4's Avatar
Yea, I think I talked to you last year about the spacers. I'd beinterested in buying them but just for the sake of hotrodding I'd rather build my own. Thanks for the offer though.
Good idea about the pipe spacers too. (Not using them that is!)
Dumb question; why doesn't blackbird sell just the brackets? Is there that much markup on the calipers? I'd think he'd sell alot more quantity if he'd sell just the parts people need. (IMHO)
soleeagle; which lugbolts did you use? Fronts or rears?
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 02-22-2005, 04:26 PM   #21
drink2mny
drink2mny's Avatar
Yup I remember. no big deal..
Easiest to answer that one is we just chose not to sell them seperately..
We found out that there were different rotors (different thicknesses) for sale.Which we found out brought on stress on the bracket. So instead of making 2 different brackets we went one type of rotor that matched what we had. We could see a potential for someone to try and sue us if their bracket broke if they installed it wrong. this way with everything we sell together we know it works..
So it became a liability issue for us..
Plus there are alot of folks that don't have or can't find a machinest or want to deal with a parts store to build a kit.
Support The Board
Old 02-23-2005, 12:37 AM   #22
soleeagle
soleeagle's Avatar
I used the lugs from the back.
Chuck
Old 02-23-2005, 03:14 AM   #23
low 84
low 84's Avatar
a ton of places sell the brackets for those of you that don't have access to equipment to machine them. price is usually from 50-75 for a set and then you just need the 3/4 ton front rotors and calipers and break lines
http://www.diy4x.com/brakes.htm
http://www.shakerbuilt.com/14_Bolt.html
http://www.offroaddesign.com/catalog/catalog.htm
http://www.bluetorchfab.com/oscomm/c...80cc2dd2df24b2
http://www.greatlakeoffroad.com/
http://www.sky-manufacturing.com/
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Thread Tools
Display Modes
