Old 02-21-2005, 11:05 AM   #1
arkracing
Weekend Warrior
Exclamation ???????????FtSuspension
will '73+ C10 Control arms bolt onto my '69 front crossmember? - do i have to modify anything for the lowers? - where they bolt on with the "u-bolts" - do the uppers bolt right on?
Thanks in advance
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 02-21-2005, 12:32 PM   #2
MrShelley
Too Many Clubs Club
MrShelley's Avatar
I have '78 upper and lower a-arms on my '68. The a-arms themselves bolt right on with no modifications. However, if you want to keep using your '69 spindles and steering components though, you'll have to swap out ball joints.
How I installed my air bags...
MrShelley is offline   Reply With Quote
Old 02-21-2005, 01:05 PM   #3
1-PU70
1-PU70's Avatar
plus if you use 73 up control arms I think you need to use the matching tie rod ends and center link. But the control arms are a easy swap.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 02-21-2005, 02:58 PM   #4
arkracing
Weekend Warrior
cool...
I don't plan on using the '69 components.
I have dropped spindles for '73+ and new ball joints for '73+ and all new steering components(inner and outer tierods/idler/pitman, drag link) for '73+ and a P.S. box '73+
The whole reasoning behind the swap is that - i need to keep my frame a "roller" as it gets put outside monday morning and comes back in on friday afternoon - due to shop space. I was going to put all that stuff on the '69 arms...but since i only use the shop on weekends it is hard for me to "dissasemble/clean/paint get the ball joints pressed in, etc.) this way i can just clean them and paint them in my basement during the week and get a front end shop to press in the ball joints so they are ready to go for a weekend project.
I want to rebuild the '73+ arms with the new balljoints/paint them...then in one day...replace the '69 arms with the '73+ arms and spindles...so that it can remain a "roller"
not to mention...there is alot more '73+ arms available than there is '67-72
Thanks guys
-'66 C10 Suburban
Old 02-23-2005, 11:09 PM   #5
Dave Reed
Dave Reed's Avatar
Let me know how that all goes I may do the same.
Dave Reed is offline   Reply With Quote
Thread Tools
Display Modes
