Old 02-21-2005, 04:00 PM   #1
Yearn4Classics
Are 69-72 4x4 Blazer and 2x4 frames the same?
Ive been wanted to restore a 69-72 2wd Blazer but cant find a 2wd Blazer for a decent price. So Ive been thinking about doing a 2x4 convertion from a 4x4 Blazer. Is it a straight swap of front and rear axles to front suspention and a 2wd rear axle?
Yearn4Classics is offline   Reply With Quote
Old 02-21-2005, 04:17 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
The front suspension is a direct swap, but you need everything off the donor truck including the steering box. You can use a 73-87 suspension as well....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-21-2005, 05:28 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
My neighbor has done this swap a few times. He re-uses the stock rearend, just puts it on top of the leafsprings with a flip kit. That gets him a 5 or 6 inch rear drop and is cheap and easy.
If you're ever in North Texas and you see a 2wd 69-72 Blazer with leaf rear springs, there's a good chance my neighbor did it.
Old 02-22-2005, 05:28 PM   #4
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
I did that conversion to a 4X4 I had. pretty straight forward 71 or 71 front crossmember, and steering box, and I think you have to shim the idler arm a bit. 2wd frame stands of right where it mounts 4x4 doesn't. Drill some holes. cut off leaf mounts. etc.... The only thing that sucks is no trailing arms. I'd try to find a 2wd frame at a junk yard.
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
Old 02-23-2005, 07:14 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
My buddy converted his over from 4x4 to 4x2 and used the trailing arms from a truck.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Thread Tools
Display Modes
