Old 02-22-2005, 05:05 PM   #1
heavy
73-87 rears into 70?
i just picked up a 44 front diff and a 14 bolt rear. the fourtten bolt is out of a 73 and the 44 is out of a 74. so my question is what kind of mods will i have to make to make these things work ie: moving spring pads/ shock mounts or are these things a direct bolt in. and also does onayone know how to differentiate between the 10.5 and 11.5 ring gears in the 14 bolt?
heavy is offline   Reply With Quote
Old 02-22-2005, 05:23 PM   #2
Senator350
Senator350's Avatar
the 14 bolt is either a 9.5" ring gear (semi float, abreviated SF) or a 10.5" ring gear (full float, abrevited FF) the difference is drastic and the full float is much more desirable. pirate4x4.com has a 14 bolt bible in the tech section but it's only usefull to you if you have the full float.
http://coloradok5.com/axleguide.shtml will show you exactly what axle you have.
all you will have to do to convert is move the spring perches.
MAKE DEAD SURE YOU HAVE THE SAME GEAR RATIO BEFORE YOU DRIVE THESE!!!
RN U OVR
Senator350 is offline   Reply With Quote
Old 02-22-2005, 05:40 PM   #3
1969 GMC
1969 GMC's Avatar
The 11.5 inch 14 bolt was not used until the late 90's, so its safe to say you don't have that. If the 14 bolt is from a 1 ton, then the spring pads will be correct, but you will need new shock mounts. If its from a 3/4 ton, you need new spring pads and shock mounts. The front axle may need shock mounts, but the spring pads are definitely ok.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-22-2005, 06:31 PM   #4
Senator350
Senator350's Avatar
i have to differ with 1969GMC...
some 14 bolt info...
1973-1987 truck, Blazer, or Suburban axles are 72 inches from end to end (measuring from the end of the axle-retaining bolts), 66-1/2 inches from wheel flange to wheel flange (with drum brakes), and the leaf-spring centering-pin holes are 42-3/4 inches apart.
For 1967-1972 trucks, Blazers, and Suburbans axles are 70-3/4 inches wide, 66-3/4 inches from flange to flange, and 40 inches from pin to pin.
there is no difference in 3/4 and 1 ton spring location on trucks in any generation that i know of.
i have a 70k10 converted to a 1 ton with dana 60 front and ff14 rear.
RN U OVR
Old 02-22-2005, 07:33 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The one tons are 40.5" center pin to center pin on the rear 14 bolt.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Thread Tools
Display Modes
