Old 02-23-2005, 07:53 PM   #1
boilerman
Question wiper motor trouble-shooting
Help!
I'm trying to fix my windsheild wipers on my '70 c20 Camper Special so I don't die the next time it rains (I live in Seattle). I've replaced the fuse, the switch and the motor. None of this worked. All the wiring contacts (both male and female) seem to be fine. I have an extra harness, but that seems overkill for what should be a "simple" fix.
Anyone have any ideas? Any help would be appreciated.
Thanks.
boilerman is offline   Reply With Quote
Old 02-23-2005, 08:26 PM   #2
krue
Designated A-hole!
krue's Avatar
I moved this to where you will get more views.
BTW welcome to the board from South Mississippi!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-23-2005, 08:38 PM   #3
boilerman
Newbie learning curve
Thanks for the help.
I'm still trying to figure out how use this forum.
Old 02-23-2005, 10:58 PM   #4
krue
Designated A-hole!
krue's Avatar
It's in the 67-72 Message Board, it's where most of us tend to hang out. As you prbobably already noticed you can still reply to it. Read up on the FAQ submission page for lots of good info.
www.daveramsey.com
Old 03-12-2005, 09:32 PM   #5
boilerman
Really. Anyone? Anyone have any ideas? Trouble shooting tips? Is there a FAQ about this particular problem? I haven't been able to find it if there is.
I'm at a loss. I'd like to reduce the time spent lying on my cab floor cursing my non-wipers.
Old 03-12-2005, 10:00 PM   #6
Mine kept cutting out and quiting because of the washer pump assembly. Not sure how you bought your replacment motor, but mine didn't come with the washer pump assembly, and didn't work right till I replaced that too. What exactly are the wipers doing or not doing? Do they work at all, just a little while (that's what I am assuming) before they die?
Make sure you have a good ground on the motor casing also.
Oh yeah....welcome tot he board.
Old 03-12-2005, 11:24 PM   #7
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Pull the plug off hte switch,see if it's getting power to the switch,if yes,pull the plug at the wiper motor,and check for power there.When you find where you're not getting power,you'll know where the problem is.If you have power at the plug on the motor,you have a bad motor,or like BIll said,and bad ground.
You can connect the clip end of a light tester to positive,and touch the metal end to a ground and test grounds that way,just in case
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 03-14-2005, 06:12 PM   #8
boilerman
My wipers don't work at all. No noise, no movement, nothing.
As for the motor, I bought it on Ebay. I tested the motor on my 71 c20 and it worked fine.
I'll try testing the power to the switch, the motor and then the ground.
Thanks for your input.
Old 03-18-2005, 02:25 PM   #9
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Memory kinda fuzzy on this one.... Seems like there were 2 differant connectors for the wiper motor. 1 style had 3 prongs and 1 two. Learned this when I was on www.partsamerica.com looking up replacement wiper motors. Ensure your connectors match up to what is on the motor. Also, if I am reading this diagram correctly, the wiper motor uses a ground seeking circuit to control the speed. With the switch off no ground is supplied to either set of windings. With the switch on low only one set of windings has a ground. With the switch in high, both sets of windings have a ground. I do not know for sure, but I do not think the wiper motor has a case ground..... The switch itself provides the ground.
So to try and answer your question directly, My first instinct is a bad switch ground. Rob the switch from your 71c20 and install it to see if it works then. The switch must be installed in the dash with a good ground for it to work. I hate to state the obvious, double check the fuse... again. If the switch is not case grounded then the wiper motor is supposed to be and you would then need to verify it has a good ground.
I happen to have the wiper motor wiring diagram here at work. PM me a fax and I'll send it to ya. A good board member to pm on this is Putter. He figured out the wiper delay mod and helped me out quite a bit with it. Good luck to ya,
Rich
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 03-18-2005, 03:26 PM   #10
chickenwing
OK, this is trying my limited computer skills... Trying to host image.
Old 03-18-2005, 03:29 PM   #11
VetteVet
Msgt USAF Ret
VetteVet's Avatar
wipe out the blues
I just found this link today on checking out the wiper motor
http://rmcavoy.freeshell.org/electrical.html
This one is the parent site.
http://rmcavoy.freeshell.org/HEI.html
VetteVet
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-21-2005, 04:22 PM   #12
boilerman
Thank you all for the input. I'll let you know how it turns out.
Thanks again.
Old 03-21-2005, 04:51 PM   #13
chickenwing
Welcome. Did you install the switch in the dash or just pull the connector, install the connector on the switch and test while holding the switch in your hand?
Old 03-25-2005, 04:37 PM   #14
boilerman
I tried the existing switch in the dash and then held the other two switches I tested while holding the switch in my hand.
The 2 replacement motors I tested in my working truck by the connectors only (the motors not installed or grounded to my dash). Both motors seemed to work fine.
Does the switch have to be grounded to the dash?
Old 03-25-2005, 04:59 PM   #15
chickenwing
Yes.
Thread Tools
Display Modes
