Old 02-24-2005, 06:02 PM   #1
doc70sub
doc70sub's Avatar
Lifting rear of '70 C-10 Sub
I'm wanting to lift my '70 C-10 Sub 2-3" to run 33x10.50x15 tires.....the front I have figured out, but what about the rear coil springs?
I'd rather not do spacers, but open to suggestions or sources or pics! LOL
Thanks!
Doc
1970 Sub C-10 - 350/TH-350/3.73 12-bolt
Came home from the hospital in it & mine ever since.
1966 Catalina Ventura 2-door fastback 389/TH400
doc70sub is offline   Reply With Quote
Old 02-24-2005, 07:15 PM   #2
TOYOTA61384
I don't know if any body has tried this or done this, but what about an axle flip kit to put the trailing arms on top of the axle? All you would need to do is weld some new perches on the axle, seems pretty straight forward, and should give you a couple inches of lift, and still have a factory ride quality.
TOYOTA61384 is offline   Reply With Quote
Old 02-24-2005, 07:16 PM   #3
doc70sub
doc70sub's Avatar
That would give around 6" lift or so....a little more than I want.
Thanks!
Doc
Old 02-26-2005, 06:39 PM   #4
chevy69er
Im lifting the rear of my '69 C-20 this weekend...i just had some custom coil springs made(3" lift).I have already did the front end awhile ago..just going to level it out a bit.New springs would be the best bet i would think...good luck with your project.
1969 C-20,383 stroker,sm465,custom long travel front suspension,4 wheel disc brakes,35" pro comps...mods under way include: 4x4 conversion,and custom bumpers.future mods include: gear vendors od unit,and relocation of fuel cell.
chevy69er is offline   Reply With Quote
Thread Tools
Display Modes
