Old 02-27-2005, 03:48 PM   #1
olblue60@aol.com
member
Suburban A/C
I am getting ready to install A/C in my suburban. My Question , Has anyone installed it in there truck? Thoughts as Original vs aftermarket? Are you satisified with the results?Its about 3 times the space as a pickup to cool. Recomendations of types, brands. "Old Air" vs "Vintage Air" vs the " Ultra Hi Performance Classic Auto air" or Original? Any feedback is greatly appreciated.Thanks
John
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 03-02-2005, 11:12 PM   #2
olblue60@aol.com
member
There are an awful lot of really smart guys on this site. Can anyone help me out? Thanks!
John
Old 03-03-2005, 09:27 AM   #3
smokekiki
Mike
smokekiki's Avatar
Check to see if any of them offer a rear unit.Maybe get the rear unit from a newer suburban or van and incorperate it into an aftermarket system.The aftermarket systems are set-up for 134.A lot cheaper to charge.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 03-03-2005, 10:11 AM   #4
bagged91
Out draggin'
bagged91's Avatar
I have an original 72 dual a/c setup that I haven't hooked up yet, I was going to put it into my 71'. Don't know how well they work. I have been looking into using the A/C out of an 88+ CK p/u for the front and a late 80's burb rear A/C unit to put into my 72'. The 88+ unit is nice and compact & should fit under the dash well. Haven't done it yet but plan to when the weather gets a little better.
I know your probably asking yourself why I am putting a 72 unit in a 71 and a later unit in the 72. The 71 is getting a 454 and I have all the correct BB a/c stuff already and the 72 I may be putting my polished TPI in and I have all the s/b serpentine brackets/pulleys/and the compressor for it already...
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 03-03-2005, 10:32 AM   #5
olblue60@aol.com
member
There is a 68 on ebay with the available aftermarket unit on the rear celing. Seems pretty generic. The hoses are even visable. Dont really like it.Can a factory rear unit be attached to a new systemand will any new system power both units?I suppose that the rear unit would have to be converted?? Thanks !Please check out the link for the 68
http://cgi.ebay.com/ebaymotors/ws/eB...531139395&rd=1
Old 03-03-2005, 11:11 AM   #6
smokekiki
Mike
smokekiki's Avatar
That is not a stock unit.On 67-71 they had a tunnel from the rear unit that ran to the front.On 72 they had a unit mounted like the one on ebay,but it fit all the way across.The newer compact units can be built into the rear side panels.The a/c lines to the rear unit are spliced into the front lines with a T fitting.There is a dash mounted switch to turn the rear off and on.
Old 03-03-2005, 12:23 PM   #7
qksilver
that unit looks like just an under dash one mounted on the roof. I have one exactly like it under my dash in my 65
qksilver is offline   Reply With Quote
Old 03-03-2005, 08:03 PM   #8
olblue60@aol.com
member
Does anyone know where I can see one of these rear units? A salesman at "Old Air' says that they have one, but no pictures are available. $640 please.Thats just for the additional rear unit. I would feel much better seeing a unit before I send cash. I thought the one in my post was the aftermarket, maybe not. I hope not; dont like the look of it.Smokekiki, so can I assume that there is no problem with an aftermarket unit powering both units? Thanks guys for your imput so far.
John
Old 03-03-2005, 09:56 PM   #9
53burb
53burb's Avatar
I have a '69 Burb. I should be receiving a rear unit from a '72 later this week or next. The techs at Vintage Air told me their unit would adapt to this fairly easily. You would either have to have the a/c hoses made locally or they can supply them. I believe they said they were about a dollar a foot. From what I have been told by many people is that the Sanden compressor, which all the aftermarket companies use, is much more efficient than the stock units and uses less horsepower. If you order an aftermarket kit, let them know you will be using this for a Burb w/rear air, and they should able to hook you up with a larger Sanden compressor. Another idea I had was to use the older tunnel a/c and block off the front two vents for the front passengers and set it up for indash a/c. This would be similiar to the way the new Burbs have thir a/c setup in that each seat has their own a/c.
53burb is offline   Reply With Quote
Old 03-22-2005, 12:06 AM   #10
Bubsco
We put a '72 unit in my '69. What switch can I find that is factory? I am just using a 3 speed generic switch for now.
Bubsco is offline   Reply With Quote
Old 03-22-2005, 06:32 AM   #11
4x4Poet
I think the 72 burb rear air units were used in later GM burbs for maybe a decade. I haven't been able to verify this. I just wanted to throw it out there in the hope that someone knows what year burbs had rear air units that bolt right into 67-72 roof mounting points. Then, with application info, maybe a junkyard find would reduce costs in the effort.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 03-22-2005, 08:40 AM   #12
olblue60@aol.com
member
Wouldnt that be sweet to know! By the way, I have decided to put a factory rear air in my truck.How much does a complete unit usually sell for? Any for sale?
Old 03-22-2005, 09:14 AM   #13
smokekiki
Mike
smokekiki's Avatar
Here is a lead on switches. http://67-72chevytrucks.com/vboard/s...threadid=98718
Old 03-22-2005, 09:25 AM   #14
olblue60@aol.com
member
Smokekiki
any info on those rear sidepanel A/Cs you mentioned in your previous post? thanks
John
Old 03-22-2005, 09:47 AM   #15
smokekiki
Mike
smokekiki's Avatar
Not really.My 99 ford van has a rear air unit that is the driverside wall.It is set up like the suburbans.The a/c lines are tapped into the front unit.
Old 03-22-2005, 02:54 PM   #16
53burb
53burb's Avatar
Bubsco,
I have temporarily mounted the '72 housing, but not the blower motor. How did you mount yours?? I figure I will have to get a piece of metal to use as a brace that will go between the two sides and mount the blower motor to that. As for the switch, I figure that Vintage Air has a control on one of their control panels. It is not original, but I am not going for that.
Old 03-26-2005, 11:17 AM   #17
Bubsco
That is right, thre are two cross members that the motor mounts to, I will try and get a pic. posted.
Old 03-26-2005, 12:11 PM   #18
Bubsco
Angry Picture of rear mount
The image is to big, converted to PDF still too big. Send me your email and I will send it to you.
Old 03-26-2005, 09:55 PM   #19
53burb
53burb's Avatar
My email is chrisx.c.peganyee@intel.com. Any pics and/or info would be great.
Old 03-27-2005, 12:59 AM   #20
Bob Moore
See my answer to rear air switch also. A lot of later subs and also conversion vans have the rear air very similar to the early subs you are talking about. I would venture to say that 50% of the burbs and 75% of the conversion vans have that option out here.
I don't have a Burb but I covet a Panel so I'm always looking for parts.
If anybody has adapted one of these units please post it here. I believe the mechanicals would work without a hitch but making the inside cover fit might be another story.
Good Luck - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Thread Tools
Display Modes
