Old 02-28-2005, 10:57 PM   #1
OldJimmy57
Big 5 lug to small 5 lug conversion.......................
Need some help guys. I have a 78 suburban with a 12 inch rotor and the big 5 lug bolt pattern. Now what I need is a rotor that will fit the suburbans spindle but that will have the small 5 lug pattern. Any of you guys ever done this before?
OldJimmy57 is offline   Reply With Quote
Old 03-01-2005, 12:24 AM   #2
SCOTI
SCOTI's Avatar
You might research a 1LE rotor from a camaro (IROC). They were 12" diameter & had the smaller 5x4.75 bolt pattern. You should be able to look up what wheel bearings they need & compare them to the truck P/N's.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-01-2005, 12:30 AM   #3
crossy
Oh,you can't buy that new
crossy's Avatar
the light, 1/2 ton, stripper type full size vans from the same era had the car bolt pattern, 5on4-3/4 , so the answer may be NEW in the parts stores if you find someone behind the counter who hasa little patience. DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 03-01-2005, 01:06 PM   #4
RockHQ
ROCKET POWER!
RockHQ's Avatar
The 1LE camaro (88-92) brake disc will come with metric studs pressed in, but with the right bolt pattern (5x4.75"). The bearings 1LE rotors use are standard A3 and A6, which also fit B-body station wagons with 12" rotors, some early Mopar A-bodies with the "big" bolt pattern and a slew of other cars i've forgot.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Thread Tools
Display Modes
