Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 03-01-2005, 09:42 AM   #1
chev406
SB to BB swap on my 74 3/4.....same motor mounts?
My truck was originally a 454 but I had a small block in it for the last 4 years or so. I'm ready to intall the 454 again, but don't remember if I had to change motor mounts or not?
My neighbors are pricks even though my yard is well maintained, so I'll have to make this swap quick! A delay would be bad news, and leave me vulnerable to attacks from the county! I have to be stealth.
motor mounts, engine bracket, are the same on 74.............right!
Thanks!
chev406 is offline   Reply With Quote
Old 03-01-2005, 10:38 AM   #2
superchevy
Got big-block?
superchevy's Avatar
They aren't the same...at least the ones in my '77 C20 aren't.
I pulled the original 454 to swap in the 468...went down to the local parts house to get new mounts...parts guy says "Chevy used same mounts for small and big blocks after '73" so he gives me the mounts...I take them home and compare to originals...they are not the same...go to different parts house and show them originals and ones I just bought...after a little research in the parts book - yes, an actual book, not computer...we find the right mounts for the big block.
Just my 2 cents
SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 03-01-2005, 11:22 AM   #3
Gray Ghost
Gray Ghost's Avatar
My 73 3/4 ton truck used the same mounts when the PO swapped in the 350 I just swapped out for a new one. As far as I know it will use the same ones.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 03-01-2005, 01:39 PM   #4
bigblock73
yeller
bigblock73's Avatar
I have always believed them to be the same as well. I replaced the 350 in Yeller with a 454...used the same mounts and everything bolted up fine. I also even used the same engine stands...even tho people have told me the big block and small block stands are the same. I alse went as far as to buy "BBC" stands from another board member, but they do not line up without having to drill holes..so I never used them. Perhaps the difference is the frames (1/2, 3/4, and 1 ton)?
Superchevy, do you happen to have a pic of yours, or a part number. I am curious and would like to find out the real story about the "sbc and bbc mounts the same?" questions that keep popping up here (for my own good as well).
bigblock73 is offline   Reply With Quote
Old 03-01-2005, 07:29 PM   #5
BIGCHEVYMAN
BIGCHEVYMAN's Avatar
same
when i pulled the 350 from my truck i swapped the block mounts from the 350 to the 454 and used the original frame mounts with no problems at all.
BIGCHEVYMAN is offline   Reply With Quote
Old 03-01-2005, 09:55 PM   #6
superchevy
Got big-block?
superchevy's Avatar
Yes, I will take a pic tomorrow. They are not the same...they are very similar, but not the same.
SC
build thread
build thread
Old 03-01-2005, 10:58 PM   #7
1FaastC10
1FaastC10's Avatar
are we talking about the clamshell engine mounts that bolt to the frame?
1FaastC10 is offline   Reply With Quote
Old 03-01-2005, 11:06 PM   #8
1971ChevyTruck
1971ChevyTruck's Avatar
Big block motor mounts= Small Block motor mounts
1971ChevyTruck is offline   Reply With Quote
Old 03-01-2005, 11:49 PM   #9
chev406
Dudes you rock I gotta get it done fast before the neighbors have a chance to
Old 03-02-2005, 12:16 AM   #10
bigblock73
yeller
bigblock73's Avatar
Technically the clam shells do not bolt to the frame, they bolt to towers/stands/plates (what ever you want to call them)...and they bolt to the frame.
Old 03-02-2005, 12:32 AM   #11
1FaastC10
1FaastC10's Avatar
ok smartass, are those what we are discussing here?
Old 03-02-2005, 07:57 AM   #12
bigblock73
yeller
bigblock73's Avatar
As far as I know, we are talking about the mounts...not the stands/towers.
Old 03-02-2005, 08:45 AM   #13
MSL
MSL's Avatar
On my 78 chevy 1/2 ton i swapped to a 454 from my small block and nothing changed other than repostioning how you mount the motor mount to the front cross member. also the block mounts where the same too.
MSL is offline   Reply With Quote
Old 03-02-2005, 09:05 AM   #14
bigblock73
yeller
bigblock73's Avatar
What do you mean? Did you mount the engine mounts in a different position on the engine stands, or did you mount the engine stands in a different position on the frame? I know the engine stands have two different sets of holes, one labeled "6" (for inline sixes), the other labeled "8" (for v8's). I am curious to know how you all have done your swaps. Mine went fine, but I don't have much clearance between my trans and floor (but I am using a 700r4 too). Swervins trans clearance is the same as mine..but it just seems too close. I have been wondering if I have things set up incorrect.
Old 03-02-2005, 05:20 PM   #15
MSL
MSL's Avatar
Here you go this is what i used out of my truck manual i hope this helps and ifg anyone wants a larger pic email me at ml2418@yahoo.com maybe someone can put it on there webpage or make it a sticky. I mounted my stuff as showed and it all worked out fine.
Old 03-02-2005, 06:29 PM   #16
bigblock73
yeller
bigblock73's Avatar
MSL, thanks for the diagram! I mounted mine the same way the pics show, except my motor mounts are the 350 variety...so I wasn't able to mount them the way "view A" shows. By looking at this diagram, it appears the clam shell motor mounts are different only in how they bolt to the towers...but not really in size. I still wish I knew the truth about the towers, and if there really is a BB and SB version...and what the differences are.
Old 03-02-2005, 06:59 PM   #17
MSL
MSL's Avatar
Well i took my motor out of a 74 chevy 3/4 ton and the towers where the same as mine and the 74 truck was factory with the 454 so i myself would assume no difference in SB or BB.
Old 03-02-2005, 07:41 PM   #18
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I still stand by my original statement that there is not difference in BBC vs. SBC engine stands.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-02-2005, 08:12 PM   #19
BIGCHEVYMAN
yup
i agree with the captain.
Old 03-02-2005, 10:25 PM   #20
corn
On mine, I unbolted the 305 & bolted the 402 right in. Only issue I had was one header tube didnt want to clear the cup style mount(DR side) on the engine but it clears now...corn
corn is offline   Reply With Quote
Old 03-02-2005, 10:43 PM   #21
longhorn71
longhorn71's Avatar
me too.changed to a big block in my 85 and it dropped into the small block mounts.
longhorn71 is offline   Reply With Quote
Old 03-02-2005, 11:14 PM   #22
superchevy
Got big-block?
superchevy's Avatar
The mounts are not the same...they might work, but they're not the same. The pics below show the differences. The mount on the right is for a '77 C20 with a smallblock (these are the mounts given to me by the parts guy because "they're all the same")...the mount on the left is the original GM mount out of my '77 C20 454/T400 truck.
Do they look the same to ya'll?
The 454 mount is longer, taller, has a different mount thru-bolt location, and has a different mount-to-tower bolt pattern.
That's why I took the smallblock mounts back and went to a different parts store to get the right mounts...the 2395's...they were exactly like the originals...I kept the box so I would know which ones to get again in the future.
So in my opinion, 3/4 ton mounts for small blocks and big blocks are different, but the book shows that a 1/2 ton trucks do use the same "small block" mount...the 2292's shown in the pics...interesting, huh?
SC
build thread
build thread
Old 03-03-2005, 08:32 AM   #23
Gray Ghost
Gray Ghost's Avatar
He's talking about a 74...they are the same for that year as well as the 73 on the 3/4 ton trucks. Not sure why the 77's are different.
Kelly
Old 03-03-2005, 09:08 AM   #24
bigblock73
yeller
bigblock73's Avatar
SC, here are some pics of my stock SB mounts (on the right), and the BB mounts I purchased from a board member. By looking at your pics, and comparing them to mine...it is in fact clear there are different mounts...but when things changed is still up in the air.
Old 03-03-2005, 10:12 AM   #25
superchevy
Got big-block?
superchevy's Avatar
All 73 - 77 3/4 ton big blocks show the same part number, 2395, for the mount. All 73 - 77 3/4 ton small blocks show the same part number, 2292, for the mount. The mounts are different...they might work for the 350 to 454 swap, but the question was "are they the same", and the answer is, no.
SC
build thread
build thread
Thread Tools
Display Modes
