Old 03-04-2005, 06:14 PM   #1
chevman-67
chevman-67's Avatar
PART#wheel cylinder
Here is a part # I can not find or cross reference FC-34142 it is a wheel cylinder made by wagner lockheed usa.maye someon can help me out.
gm's are #1
1967 chevrolet short step
1988 chev 4x4 1/2 ton
1989 gmc 1/2 ton
1991 chev 1/2 ton 4x4
1993 Jeep grand cherokee 4x4
And yes a 94 Ford Mustang.
chevman-67 is offline   Reply With Quote
Old 03-06-2005, 02:15 AM   #2
Gator70
Gator70's Avatar
chevman, are you looking for one of those wheel cylinders?? If so what is the appl.
1970 GMC K15 - Canadian built
2nd Owner truck 68k miles
2014 Denali 1500 6.2L
Gator70 is offline   Reply With Quote
Old 03-06-2005, 12:34 PM   #3
chevman-67
chevman-67's Avatar
This is off a 1 ton dually gmc 1969 w/v-8 I have replaced it but I could not cross reference this part # and the 1 I installed is fine but not an exact match and was wondering if wagner still made these or or they all aftermarket now.I paid $125 .for the 1 I replaced and if I ever need to do this again might be able to find 1 cheaper if I had a cross on the old part #.
gm's are #1
1989 gmc 1/2 ton
Old 03-07-2005, 12:22 PM   #4
Gator70
Gator70's Avatar
Well chevman, I looked through the Wagner catalouge and could not produce that number, it didnt appear in the superceded #'s. or in the price list.
The numbers that I found for that were different.
The fronts 1 1/8 bore are F34333/F34334
The rears w/HO72 1 1/4 bore F9344/F9345
The rears wH110 1 1/2 bore upper F57851 lower F57850
These are all Wagner part no's
Hope this helps a little bit.
If you get the casting no of the old cyl that might help to get the newer replacement
Old 03-07-2005, 04:40 PM   #5
chevman-67
chevman-67's Avatar
Thanx I do know its a 1 1/4" bore the #s I have are off the rubber end caps off the cylinder ill try and get 1 off the cyl, itself .Thanx again.
gm's are #1
1989 gmc 1/2 ton
Old 03-08-2005, 12:01 PM   #6
Gator70
Gator70's Avatar
The dust boot(end cap) numbers are not individual to each cylinder. If you know the bores are 11/4 then the F9344/9345 are the cyl you need. I can double check from the casting no of the original cylinder as well.
Thread Tools
Display Modes
