67-68 grill moulding clips.
I am having problems installing the new clips into my new GM grill moulding clips. The clips pop out of the moulding when I tighten the clips down. It's like the clips are too small. Anyone else had problems like that ?
Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Too many is never enough!
A friend of mine that does restorations never uses new clips. He says they are too small even when bought through GM. That's why he saves every single decent used clip he finds. Cleans em up and they work as originally designed. I believe they've had this problem for years so I can't believe there hasn't been enough complaints to force a remedy!?
I should add that I only know this for sure on 69-72 lower mouldings but I'm assuming there must be a similar problem with the 67-68.
Jason 1968 K10 SWB Fleetside 1971 K2500 GMC LWB 1968 K20 (later frame, donor body) 1972 C20 LWB parts truck 1993 K2500 Suburban, tow rig, 454, 4L80E NEW!! 18' Siem's car hauler 2004 Honda Odyssey (family man!) |
I have used both and I make sure that they are turned tightly before I tighten the nut as they are a half turn type bolt are the little wires still on them? I have never had 1 pop out when installed properly.I know the lip is not large on the molding but have patience.
gm's are #1 1967 chevrolet short step 1988 chev 4x4 1/2 ton 1989 gmc 1/2 ton 1991 chev 1/2 ton 4x4 1993 Jeep grand cherokee 4x4 And yes a 94 Ford Mustang. ![]() ![]() |
Well I am a Idiot.
I was instaling the clips the wrong way...The round edge needs to go into the lip. I was putting the squared edge in as the grabbing edge. Thanks for the help.
Thread Tools | |
Display Modes | |
