Old 03-12-2005, 01:45 PM   #1
ocbaud
Garage Queen Material
tranny leaking problem??
ever since i changed my speedo gears, the speedo cable housing is leaking a little bit. i didnt see anything like a gasket or o ring sealing it before. what is the problem?
ocbaud is offline   Reply With Quote
Old 03-13-2005, 09:30 AM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Are you talking about the "bullet" which the speedo cable screws onto or the rear housing? Both should have an o-ring around them. I have had to replace the "bullet" before because the internal seal was bad. You probibly need to replace the o-ring, in a pinch some RTV will work.
NeCrOmAnCeR is offline   Reply With Quote
Old 03-13-2005, 11:51 AM   #3
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yeah, if thats what your talking about there should be a little o-ring to replace.
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Thread Tools
Display Modes
