Old 03-14-2005, 11:14 PM   #1
whitesswj
Embrace the Redneck
whitesswj's Avatar
WTB or trade: drive shaft!
I'm in need of a drive shaft for a 68 w/ a short tail 3 speed coarse spline output shaft.
Measurements of the current drive shaft:
from end of fnt yolk to center of rear u-joint: 77.5"
from center of fnt u-joint to center fo rear u-joint: 72.75"
(someone correct me if i'm wrong) this one is a 2 piece and is useless to me and if anyone wants it it's up for grabs or trade.
and what i think i need is about 4 to 7" longer (I'm really not sure)
I'd really like a one piece shaft but a dual will due.
Imput anyone
thanks sswj
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 03-14-2005, 11:21 PM   #2
bisquik65
bisquik65's Avatar
Is yours a short bed? I just pulled apart a 68 6cyl 3spd longbed. It has the big spline input.
bisquik65 is offline   Reply With Quote
Old 03-14-2005, 11:29 PM   #3
whitesswj
Embrace the Redneck
whitesswj's Avatar
you know that's a good detail that i failed to menton. I have a LWB pickup.
one question. is the front drive shaft the olny part i need if i stick with a 2 piece?
mind you i need a shaft for a V8 3 speed short shaft
thanks sswj
'01 Camaro
Old 03-14-2005, 11:33 PM   #4
bisquik65
bisquik65's Avatar
I have exactly what you need here. A 2 piece shaft,out of a 48k 68 C/10 6cyl 3spd.longbed $50 shipped. I will have to take it apart so it can be shipped,Let me know,Erick
Old 03-14-2005, 11:37 PM   #5
whitesswj
Embrace the Redneck
whitesswj's Avatar
are you sure it's just right? the inline's were set backward in the compartment more than the V8 so the shafts were shorter. I just moved the tranny up into the V8 position. are you sure?
'01 Camaro
Old 03-14-2005, 11:38 PM   #6
bisquik65
bisquik65's Avatar
I will get you measurements of it tommorow,To be sure.. Is that o.k.?
Old 03-14-2005, 11:39 PM   #7
whitesswj
Embrace the Redneck
whitesswj's Avatar
oh yea. thanks sswj
'01 Camaro
Old 03-15-2005, 03:18 PM   #8
whitesswj
Embrace the Redneck
whitesswj's Avatar
ttt
'01 Camaro
Old 03-17-2005, 02:03 AM   #9
whitesswj
Embrace the Redneck
whitesswj's Avatar
hey bis, do you have those measurements?? thanks sswj
'01 Camaro
Old 03-17-2005, 09:38 AM   #10
bisquik65
bisquik65's Avatar
This darn board messed up right when i was going to do that, I will get them to you. Let me go out in the snow and measure it. ,Sorry about that.Erick
Old 03-17-2005, 10:05 AM   #11
whitesswj
Embrace the Redneck
whitesswj's Avatar
thanks.
just keep in mind that you've got to take your truck out of commission in order to make iy better some times
sswj
'01 Camaro
Old 03-17-2005, 10:17 AM   #12
bisquik65
bisquik65's Avatar
I have roughly 78 inches from tip of yoke to rear of shaft,Sound right,Corse 3 spd spline too. Let me know Let me get a pic of it right fast.
Old 03-17-2005, 10:26 AM   #13
bisquik65
bisquik65's Avatar
pics,snow is free!!!
Old 03-17-2005, 10:33 AM   #14
whitesswj
Embrace the Redneck
whitesswj's Avatar
that's the same measurements that i have now. except i've got 77.5 from center of rear joint to tip of yolk.
That one won't work but i may need that yolk though. keep me in mind. thanks, thanks alot. sswj
'01 Camaro
Old 03-17-2005, 11:38 AM   #15
whitesswj
Embrace the Redneck
whitesswj's Avatar
TTT. still need a drive shaft that's about 6 inches longer than the one i have.
thanks. sswj
'01 Camaro
Old 03-17-2005, 12:14 PM   #16
bisquik65
bisquik65's Avatar
Do you by chance have the 3 speed bolted by the tailhousing to an automatic crossmember?
Old 03-17-2005, 08:11 PM   #17
whitesswj
Embrace the Redneck
whitesswj's Avatar
not that i know of. the person i bought the truck from had a 327 with a Munice 4 speed in it but pulled that out and i then bought the truck.
sswj
'01 Camaro
Old 03-17-2005, 08:41 PM   #18
bisquik65
bisquik65's Avatar
Does it have an alumn.bell housing? All trucks 67-72 used the cast iron bellhousing that bolts to the manual crossmember on the bottom with 2 bolts. I think thats the problem you are having. The only driveshaft that is longer is off a longhorn...
Old 03-17-2005, 08:57 PM   #19
whitesswj
Embrace the Redneck
whitesswj's Avatar
it has a cast iron bellhousing. the pickup had a 327 and a munice 4 spd in it. how's it possiable? help please??
'01 Camaro
Old 03-17-2005, 09:05 PM   #20
bisquik65
bisquik65's Avatar
Are your motor stands in the front holes or the rear set of holes? If they are in the front holes,they are more that likely 6 cyl stands. And that would explain the 4 inch difference you need? Just trying to help you figure this out,Erick
Thread Tools
Display Modes
