Old 03-23-2005, 11:17 AM   #1
chuck call
chuck call's Avatar
Arrow looking for rear end in mo.
Looking to change gears in 10 bolt 8 lug Rear End. I believe its a 5:11 or 5:14 Im in Bolivar near Springfield Mo...
chuck call is offline   Reply With Quote
Old 03-23-2005, 02:38 PM   #2
nu2-72
What to what? would you take a 14FF or corporate? Location helps too. Give as much info as you can. It helps alot.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 03-23-2005, 02:53 PM   #3
Chris H
72 C30 Trailer Queen
Chris H's Avatar
I have a complete Dana 60, 4.10 gears and posi, 2wd leaf spring.
$300.
Where in MO are you?
I could probably get it to Independence for some gas money.
PM if interested.
Chris
Chris H is offline   Reply With Quote
Old 03-23-2005, 07:37 PM   #4
chuck call
chuck call's Avatar
I just bought a 1972 3/4 ton truck nice but at about 55 mph Im at red line I think the rear end is about a 5 something im not sure im trying to find out the difference between a eaton rear end and I believe is a ho52 it is 10 bolt 8 lug ive seen acouple of pictures but am not for sure, I want to gear it for more highway speeds is there any thing else i can switch to without much work also have some parts that i have aquired with the truck, wing glass with frame, passenger side fender, door glass,window regulators, hood but has dint on front not bad but could probobly be fixed springfield mo.
Old 03-23-2005, 07:53 PM   #5
chuck call
chuck call's Avatar
From 514 to a 373 or 411..What is a 14FF? or corporate? Im in Spfld, Mo.
Old 03-23-2005, 07:56 PM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Well if it has a round removable cover and drop out center section, then it is a corperate axle, also refered to as the eaton. 4.10 is the best you can shoot for. It was replaced in1973 by the 14 bolt full floater.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-23-2005, 07:57 PM   #7
chuck call
chuck call's Avatar
$300.
PM if interested.
Chris
Will a dana 60 take the place of eaton 10 bolt 8 lug coil spring?
Spfld, Mo.
Old 03-23-2005, 08:01 PM   #8
chuck call
chuck call's Avatar
Is this also known as a pumkin this is new to me just got the truck, will a 73 full floater replace this?
Old 03-23-2005, 08:12 PM   #9
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
yep, and yes a dana 60 will replace it. I have a dana60 in my 70 and the eaton in my 71, both 3/4 tons. Do you need leafs rear or coil springs and 2wd or 4wd? The leaf springs spacing is different between 2wd and 4wd, 42" v. 40". The one ton rears are also 40". For a 14bolt full floater from a 73 and up, look for a 1 ton rear as the spring spacing is 40.5' or a 3/4 ton version wich will be 42.5".
Old 03-23-2005, 08:28 PM   #10
chuck call
chuck call's Avatar
it is a coil spring and 2wd
Old 03-23-2005, 08:34 PM   #11
chuck call
chuck call's Avatar
also willl i need to go from a two piece drive shaft with carrier bearing to a regular driive shaft?
Thread Tools
Display Modes
