Old 06-05-2002, 05:29 PM   #1
WB72
Before and After
WB72's Avatar
can I use blocks to lower the rear of my 72?
Would I be able to use blocks to lower the rear of my coil spring 3/4 ton 3 or 4 inches?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 06-05-2002, 06:02 PM   #2
Stepside
Gasser
2 inches is the most you want to go with blocks. Any more, the trailing arms will be WAY low.
:thud 70 sstep tubbed, Muncie, double hump, snowflake,
Stepside is offline   Reply With Quote
Old 06-05-2002, 06:17 PM   #3
WB72
Before and After
WB72's Avatar
I'm not sure I understand that. If I use blocks, wouldn't my trailing arms be in the same place, and my axle raised? I am concerned about the axle hitting on the frame. as well as the angle of the driveshaft.
66,000 miles.
Alberta, CANADA
Old 06-05-2002, 06:26 PM   #4
Brian19692
raising the axle will make the arms closer to the ground
67 short 2wd. FOR SALE
69 long box w/72 grill
69 Camaro 327 4-speed
Des Moines, Iowa
Brian19692 is offline   Reply With Quote
Old 06-05-2002, 06:31 PM   #5
WB72
Before and After
WB72's Avatar
Ahhh,
Lower to the ground, in comparison to lower from the frame.
Gotcha. Thanks it makes sense now.
66,000 miles.
Alberta, CANADA
Thread Tools
Display Modes
