Old 03-31-2005, 02:38 PM   #1
69ride
All Go, No Show
69ride's Avatar
What is this?
And what does it do? And do I need this?
This is a 67 283.
69 LWB
Rebuilt 283, aluminum intake, edelbrock carb, Mild Melling Cam, HEI.
69ride is offline   Reply With Quote
Old 03-31-2005, 02:46 PM   #2
Livrat
Member #1049
Livrat's Avatar
That is part of the crankcase breather/PCV system which is not used after 1968... it is not needed if you plug the hole on the top of the block with a "freeze plug" and use a PCV system from a later small block that uses it through the valve covers. but if your valve covers do not have any holes you definately need it.
Livrat is offline   Reply With Quote
Old 03-31-2005, 02:49 PM   #3
69ride
All Go, No Show
69ride's Avatar
Thank you. I am running the newer style valve covers with PCV valve.
69 LWB
Old 03-31-2005, 03:06 PM   #4
Livrat
Member #1049
Livrat's Avatar
then just head down to your local auto parts store and pick up a metal freeze plug, put on some sealant and tapp it in the hole in the top of the block and remove the can in the valley
Old 03-31-2005, 03:07 PM   #5
Livrat
Member #1049
Livrat's Avatar
if you like, you can also remove the oil filler tube on the intake manifold and plug it too. If you leave it on be sure to have a solid cap on it and not a breather cap
Old 03-31-2005, 03:39 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
I learn something new everyday....
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Thread Tools
Display Modes
