Old 06-08-2002, 03:55 AM   #1
cwilkie
Chance
cwilkie's Avatar
Question Speedometer Problem??
What causes a speedo to jump around when I'm accelerating? Why doesn't it move smoothe? And What kinda of flywheel/flexplate does a 396 engine and a turbo 400 auto trans use? With the weight or without the weight? Thanks!!
Chance
cwilkie is offline   Reply With Quote
Old 06-08-2002, 05:07 AM   #2
bigvinnie
bigvinnie's Avatar
your speedo cable probably needs to be lubed, just unscrew it from the back of the speedo.... you can try some light oil where the cable enters the speedo first... then if that doesn't cure it you can try the other end where it enters the trans... last resort is to pull the cable core out completely, lube it and re-install...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 06-08-2002, 10:19 AM   #3
jhwkns
Registered Cruiser
jhwkns's Avatar
New speedo cables are only about ten bucks.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Thread Tools
Display Modes
