Old 04-08-2005, 01:51 AM   #1
drh1485
Under hood wiring
I am needing to replace the under hood wiring in my 70 GMC. Who is the best to get that from? I have also heard you can upgrade to an internal regulator.
drh1485 is offline   Reply With Quote
Old 04-08-2005, 08:01 AM   #2
JimKshortstep4x4
Talking
GMC Paul's is a good source and there are others.
Check it out. http://www.gmcpauls.com/wiring_harnesses.htm
Jim
Old 04-08-2005, 10:45 AM   #3
Putter
More Cowbell....
Putter's Avatar
If that is a 'stock' harness, and you still want to go 'internal', check out www.chevyduty.com and look at part number 52-896. It is a alternator conversion kit. The same proceedure is discussed in the FAQ section, but this is a plug & play conversion if you don't want to look at the cut/spiced wires. Plus, it's only $14.95.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Thread Tools
Display Modes
