04-08-2005, 08:58 PM | #1 |
are these ramhorns any good?
curious if these would be any good for performance...
http://cgi.ebay.com/ebaymotors/ws/eB...966456442&rd=1 or http://cgi.ebay.com/ebaymotors/ws/eB...965570934&rd=1 there new, but i aint sure if there jap or not
1987 350 TBI lowered 5/7 Last edited by bigarmzz; 04-08-2005 at 09:03 PM. |
04-08-2005, 09:26 PM | #2 |
Tonawanda 454
you're better of finding a decent set of headers or manifolds... the ramhorns from what ive heard tend to overheat or cause other problems in this area, most specifically causing major rubbing/burning of spark plug wires in short times.
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
04-08-2005, 09:55 PM | #3 | |
driving is in my blood
Thats 100% not true. I only wish my headers gave me the clearence my ramhorns do. Only problem area is the motor mounts needs a slight bit cut off to clear the collector. Absolutley not a problem or somthing that comprimises strength. Now I did have my MSD wires lay directly on the manifold when I first was putting the truck together, and they burned threw quickly. They'll also do that when you lay them on headers My borg-warners that replaced them also layed on them on a drive once [before I got wire holders] but they had no problems at all As to the Q- theres no "jap" ramhorns that I know of, and it wouldn't matter if they were. The ramhorns you linked are both 2" outlet manifolds, a slight increase in performance compared to stock manifolds. Probably not worth the hassle of changing the exhaust to fit them.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
04-08-2005, 10:46 PM | #4 |
Happy to be here
Tom has the correct answer, and he speaks from experience not rumor. To add to what he said, those are 2" ram horns. The first set is truck style and the second set are Corvette style.
If your looking for performance gains and don't want to run conventional headers you will need 2.5" ramhorns. They can be bought from GM as part # 3797901 (left) and 3814970 (right).....
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 04-08-2005 at 11:00 PM. |
04-08-2005, 11:31 PM | #5 |
Web Wheeler
The angled ones are perfect. The straight-down dumps need the driver's engine mount trimmed a little. (I did it with a torch as I was putting them on )
Burnt plug wires are not a problem.... you need to get a long set and feed them around the back and underneath. You will need to change or bend the dipstick - it will be in the way. I put dual exhaust on at the same time... I liked the sound and my perceived power. I have no data to verify how much power I got out of it.
'66 C10 longstep - Clifford equiped '84 C20 Suburban 6.2L - awaiting 4x4 conversion '91 V3500 Crewcab - awaiting diesel swap |
04-08-2005, 11:40 PM | #6 |
Great information!
How about a comparison of the 2.5" Ramhorns and headers? I don't know much about them. I was thinking of going with headers until a friend of mine who is more mechanically inclined than I am advised that they are prone to exhaust leaks and make changing spark plugs a challenge. He actually welded his to the exhaust because he was tired of leaks. I'd rather leave my truck stock than deal with a bunch of problems. Is there any downside to the Ramhorns? They seem like a good compromise. A pretty much stock setup with more power. Will the part numbers listed above bolt right up to a 350? Thanks! |
04-08-2005, 11:51 PM | #7 |
Go with the 2.5" Ram Horns. The next best thing to headers with No Headaches. Custom build you plug wires with straight plug boots.
Real Trucks are Built not Bought Building: 1981 GM SB LowRider 1985 GM K3500 3+3 1981 GM K2500 SSB 1980 GM K2500 X-BC Hydro 1979 GM K3500 3+3 1976 GM K5 Blazer 1970 Custom 10 http://bc4x4.com/ Last edited by Truckstuff; 04-08-2005 at 11:53 PM. |
04-09-2005, 12:29 AM | #8 | |
04-09-2005, 01:01 AM | #9 |
Professional Grade
I was gonna ask how the heck he managed that underhood picture with the hood closed, then I noticed the lack of inner fenders, lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
04-09-2005, 05:15 AM | #10 | |
man, damnnnnn good info here.... this should be a sticky i went to GMpartsdirect.com , typed in those part numbers above....and the 3814970 says "no parts found matching this number"????? the part # for the left one you gave worked...$108 thanks n2trux
1987 350 TBI lowered 5/7 Last edited by bigarmzz; 04-09-2005 at 05:21 AM. |
04-09-2005, 08:13 AM | #11 |
Tonawanda 454
i just tried making a comment from what i have heard to relay a point...
this is why i am a member here, to learn this stuff as well. with the information given, i may have to look into some myself if i decide to keep (or fail to sell) my 76.
04-09-2005, 10:09 AM | #12 | |
Happy to be here
It seems every time this subject comes up, someone has a negative comment about Ramhorn manifolds. I think that comes from people having problems with the truck style cracking. The 2.5" Corvette style manifolds are a very good choice for most people. If they are port matched they will flow "almost" as well as many shorty headers. They won't flow as well as long tubes, but you don't have to deal with them blowing gaskets either. Here are a couple of pic showing plug wire routing.... |
04-09-2005, 10:14 AM | #13 |
Happy to be here
The ones with the generator brackets can be modified fairly easy. Although I have never done it, I have been told the bracket can be cut of with a band saw or cut off wheel, and the manifold smoothed out with a sander and course paper.
If you want to spend a little more money you can buy them from Classic Chevy without the generator bracket. They are listed as Part# 24-111 and sell for 399.00 a set- Classic Chevy |
04-09-2005, 11:14 AM | #14 | |
Real Trucks are Built not Bought Building: 1981 GM SB LowRider 1985 GM K3500 3+3 1981 GM K2500 SSB 1980 GM K2500 X-BC Hydro 1979 GM K3500 3+3 1976 GM K5 Blazer 1970 Custom 10 http://bc4x4.com/ Last edited by Truckstuff; 04-09-2005 at 11:15 AM. |
04-10-2005, 09:04 PM | #15 |
laying low
OT for a sec. Ken, that small block in the black rod has got to be the finest lookin hot rod engine around, bar none. That thing is a beaut.
And the chromed rams look right at home on it too.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
04-10-2005, 09:59 PM | #16 | |
Happy to be here
04-10-2005, 11:24 PM | #17 |
Until Seventy Times Seven
Can we add another second to OT.
N2 - Is that the Scotty Gray that has a few rods built by Boyd? If so, I believe he had Boyd build that 32, the 'Aluma-Tub', a sixty-four(?) Mustang for his wife as well as a 'few' others. Got any pics of some of his other rods?
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
04-10-2005, 11:43 PM | #18 |
Happy to be here
Yep that's the infamous Scotty Gray. He sold a bunch of those cars at the last Barret-Jackson auction. My buddy Keith said he just bought a bunch more though.
Here's one you didn't mention. Another Boyd car called Whathehaye.... Last edited by N2TRUX; 04-10-2005 at 11:44 PM. |
04-11-2005, 12:57 AM | #19 |
I've seen pictures of that rod, but I didn't know that Boyd had built it. I remember seeing a show where a coachbuilder (not Marcel) was crafting a similar 'European-style' rod. I never saw the finish product. Maybe, it's the same one. Regardless ...
Thanks for the pics and the info.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... Last edited by boxrodz; 04-11-2005 at 11:38 PM. |
04-11-2005, 09:33 AM | #20 | |
Happy to be here
04-11-2005, 06:45 PM | #21 |
geeeeeezzzzzz
1987 350 TBI lowered 5/7 |
04-11-2005, 11:37 PM | #22 | |
Must be the shoes.
04-12-2005, 12:12 AM | #23 |
Do they make these manifolds for big blocks? I don't see any on ebay...
04-12-2005, 01:45 AM | #24 |
Not that I know of.
04-12-2005, 09:20 AM | #25 | |||
Insert Witty Text Here
Can the one with no bracket be run on both sides? If it points straight down, it should not matter, should it? Does it interfere with the dipstick, maybe? Slonaker Last edited by Slonaker; 04-12-2005 at 09:21 AM. |
Thread Tools | |
Display Modes | |
