Old 06-09-2002, 04:39 PM   #1
WORNBRAKES
Question need help, lights are crazy
My brake lights are dimmer than normal. Front parking lights come on when you press brake pedal. Turn signals are strong. Suspect a bad ground somewear but don't know were to start. If any one can help, I would apreciate it. Thanks.
Mario
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 06-09-2002, 05:40 PM   #2
WORNBRAKES
Got power to the fuse panel and all the way pack. What would only affect the brake and tail lights but not the turn signals?
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-09-2002, 05:57 PM   #3
Mitzki5
"TRUCKLESS"
Mitzki5's Avatar
Check your blinker fluid! hehehehe Just kidding. Sorry, but I can't help you. You came to the right place for the answer though. These guys and gals know their stuff. Good Luck
Mitzki5
No longer have an old truck! But always looking for another one!
Mitzki5 is offline   Reply With Quote
Old 06-09-2002, 06:04 PM   #4
Zkast
Zkast's Avatar
Make sure you dont have a 1056 (single element bulb) in place of a 1157 (double element bulb). It will cause your tail lights to illuminate whenever the brake lights are powered. It's back feeding the parking light circuit with power from the brake lights.
If the 2 rear bulbs are fine, start looking into the turn signal switch. Your brake light power is fed through the switch as is your turn signals and parking light circuit. If the switch is shorted in some area's it will also allow a backfeed problem.
Zkast is offline   Reply With Quote
Old 06-09-2002, 06:08 PM   #5
daveo68
daveo68's Avatar
Had a grounding problem on my truck last year.Took three days to find.Finally pulled tail light lenses out,had some bolts loose on one of the tail light assemblies.I had basically same symptons.
68 C-10 Custom LWB
307 V8
Lexington,NC
davideowens@lexcominc.net
God Bless America
daveo68 is offline   Reply With Quote
Old 06-09-2002, 06:36 PM   #6
WORNBRAKES
Thanks for the diff aproaches. I have 1157 bulbs in the rear. I am still cahasing wires and finding some exposed wires that may bee bleeding into each other. Going to fix those, check fluid lol, and keep troubleshooting.
Thanks,
Mario
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-09-2002, 07:24 PM   #7
Mountain Man
I also have the exact same problem. When I apply the brake, my right front (passenger side) signal light goes on. I am also in need of a fix.
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 06-09-2002, 07:43 PM   #8
blue_69
someday
blue_69's Avatar
that problem is either a bad ground, wires melted together, or possibly a bad signal switch . I'm not 100% sure on the signal switch i havent had to mess with one in a while but i have seen that happen on newer cars.
blue_69 is offline   Reply With Quote
Old 06-09-2002, 07:58 PM   #9
chevy72402
FARMER/RANCHER
chevy72402's Avatar
It sounds like a bad ground and the power is backfeeding through the park lights to find a good ground.
1972 chevy super, long box, 402 big block (2,000 miles on rebuild) 2wd tach, tilt, tool box on bedside, a/c, sliding rear window, orange and white.
1972 Chevy Blazer 2wd, tach, tilt, a/c, my first engine overhauling experience, Orange, with white top
2006 Gmc Sierra, XM, Z-71, dark blue, onstar, leather, rear entertainment (audio only) heated seats, (the wife loves that feature) upgraded tires immediately after purchase to Goodyear Wrangler AT/S (hate those rock throwers that come from the factory)
BWC
chevy72402 is offline   Reply With Quote
Old 06-09-2002, 08:14 PM   #10
WORNBRAKES
Thumbs up
I started aft and have been working forward. About to start on the turn signal switch. Any ideas of wear to start here b/c I realy don't want to rip everything apart. I replaced all of the old splices in the back and added good wire were there was chafed wires. I will just keep chasing wires. Aint that a b$&ch.
Thanks for all the advice,
Mario
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-09-2002, 08:20 PM   #11
chevy72402
FARMER/RANCHER
chevy72402's Avatar
it still does it after you replaced those wires? and you checked your grounds for rust and stuff?
BWC
Old 06-10-2002, 12:15 AM   #12
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Put a 2x4 between the under side of the dash and the pedal. Either that or find your brake switch and pull it back far enough to turn it on.
Then get a volt meter and measure for any voltage drops in all the areas where the ground should be flowing. If you measure any volts over 1 or so, you've found a bad ground connection.
By this I mean check the voltage between the taillamp housing and the bed. Then check the bed to the frame. Then check the frame back to the (-) battery terminal. Somewhere you should find your problem if it's a bad ground. If the back doesn't expose the problem, check the front. You can also use a black wire clipped to the battery (-) as a reference point. All "grounds" should read zero volts back to the (-) terminal. Anywhere you find voltage on a frame part means there's something wrong.
If you don't have a volt meter, you can use a 12V lamp. If it lights up, even a little, you're getting real close to solving your ground problem.
Hope this helps.
Keep us posted.
Oh another thing popped into my head... Check your sockets for the taillight bulbs to be sure they're getting a good ground to the shell of the bulb. That type of problem is a real ***** to find. Troubleshoot it with a piece of wire to ground the shell of the bulb to the chassis (or even (-) battery terminal.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 06-10-2002, 12:56 AM   #13
WORNBRAKES
It' funny. I replaced the aft harnes about three monthes ago. Today, I ended up replacing all the wires from the fire wall back to the aft harness. Found some of the wires to be chafed and grounded to the frame and eachother were the clips are. Also found some bad splices about mid body with broken wires. After all that I had the wife help with signals and lights. Found tail lights to work ok, left turn signal ok, but when you use right signal you loose the tail light on that side.
When I was done for the night, I started the truck to charge the bat and about every 3 seconds I would hear a tick tick from the alt. That is unusual. I'm thinking in the morning I will check the alt first thing. Then I will check all wires under dash again. So far I seem to have power wear I should once the wires were replaced.
Thanks to all members for advice,
Mario
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-10-2002, 02:16 AM   #14
Hooter
My other Love
Hooter's Avatar
I know this has already been said but it sounds to me like you have a single element bulb in a doublke element socket or your truck is possesed by Satan
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 06-10-2002, 04:22 PM   #15
WORNBRAKES
I now have the dash pulled apart [going to install dash pad while I am here(thanks LeRoy)] chasing wires under there. I am finding that when I turn on the lights, my signals are charged at that point. That don't seem right. They should be charged when I turn on accesories and use the signal.It has been said before but do you think my turn switch is bad? If so how is that replaced? I hope I find a bad wire. Just sounds a lot easier.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-10-2002, 05:19 PM   #16
WORNBRAKES
determined switch is bad. When I turn on signal left or right they both get power and are blinking. If I dont have acc on and I turn lights on I get no taqil lights. If I have lights on no acc and use turn signals I get tail lights. Going to try the yard for a switch If not wear is a good place to get one fast?
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-10-2002, 07:08 PM   #17
71GMC_3/4T
71GMC_3/4T's Avatar
Napa has good ones. Unfortunately they may not have the exact connector you have. They do give you an adapter cable, but I extracted the pins and rewired it the way I wanted it. Don't mix up the wires if you do this though.
My truck had a messed up turn signal switch when I got it. Lucky for me it didn't cancel and I shotgunned the whole thing. While I was changing it out, I found where some idiot had spliced a couple of the wires in the switch harness. That would have taken me hours to find...
Lafayette, CO
Old 06-10-2002, 11:08 PM   #18
WORNBRAKES
Replaced the switch. Looks like it needed it, as you can see. Still have same prob. I might have hazards again thanks to new switch. With rear bulbs installed, I get no tail lights unless I turn on the signals with no accesory power.Funny. I can tell this by the neat little lights on the tow harness. Never thought I would need them.If I turn on lights, now accesory power and remove bulbs, I then get power to on pin whitch tells me that would be tail lights. Does that make sence? Maby the pins in the taillamp harness are grounding? I can't find any wires under the dash to be bad. I have been using the Haynes and a spare under dash harness to chase these wires down. Does any one know of a better manual for wire diagrams? I need one that tells you weither the wire is power or ground. Haynes just shows color, size and wear they go to and from. Well back to the truck I go, I need to tackle this.
Thanks,
Mario
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-10-2002, 11:11 PM   #19
WORNBRAKES
I seemed to get the dash pad installed though. lol
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-10-2002, 11:43 PM   #20
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
All the wires are hot at one oint or another...the body is the only ground you need.
Check this link for schematics.
Old 06-11-2002, 02:17 AM   #21
WORNBRAKES
I think I have the problem issolated. The wife walks in the garage to bull sh!t and after shee is done I try to explain it all to her. Me, I am confused, frustrated, pissed and on my way to being drunk at this point. I explained everything to her using the spare harness that I use to make it easy to chase wires. Finaly she said "wear is the main problem", I told her it was that I am getting power to all 4 tail wires wwith the lights on when only the wire from the light switch should have it. She told me to disconnect it and then check it. I did and everything was as it should be. So her little smart a$$ figured it out after I have spent a day and a half lookking at it. lol
Thanks for all the help, I am going to the yard tomarow to find the firewall plug. I have a spare under dash, so I hope the truck is on the road in the afternoon.
Back to the basics for me!
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-29-2002, 01:22 PM   #22
WORNBRAKES
ttt
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-29-2002, 03:24 PM   #23
hanssolo
hanssolo's Avatar
Would it be safe to say bad grounds are 80% of old vehicle electrical problems? Also, all you guys with pretty flashing pictures on your posts, I'm jealous! I want one too!
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
Old 05-15-2011, 06:53 PM   #24
elf w/capital T
Re: need help, lights are crazy
damn, im having this problem now, my brakes light are on, my front passenger side turn signal stays on too, but with the blinker on, it works as advertised. hmmm bad ground somewhere, when i get it i WILL post. thanks for the help everyone though
elf w/capital T is offline   Reply With Quote
Old 05-15-2011, 08:04 PM   #25
Longhorn Man
sweet... 9 year old threads rock!
Elf, by chance, is the flasher removed for your 4 ways, and the button broken off, in the on position?
Thread Tools
Display Modes
