04-14-2005, 02:34 PM | #1 |
4spd to turbo 400?? Help
Will a turbo 400 bolt right into my truck if it has a 784spd in it now?? If so would I be able to run a ratchat shifter w/ a 2in body lift??
Jesse 72 4x4 Sold 59 GMC air ride ls swap |
04-14-2005, 03:13 PM | #2 |
No. I am guessing you have the NP205 since you didn't say. If thats the case you will need the TH400 to NP205 adapter, which is $$ if you can even find one, from a 77-84 K30 1 ton truck. Then you will need a 32 spline input gear for your transfer case, about $150, and then have the bearing hole bored out for the larger bearing, around $40-50.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
04-15-2005, 04:55 PM | #3 |
will a turbo 350 or a 700r4 fit??? and yes i have a 205 o and it is a 72
Jesse 72 4x4 Sold 59 GMC air ride ls swap Last edited by Jesse72; 04-15-2005 at 05:06 PM. |
04-15-2005, 06:01 PM | #4 |
No, I believe your 205 is a 10 spline version, so you will need to find the correct adapter, and input for any tranny you want to install.
Or just find a TH400 with the transfer case and correct adapter, and then sell yours. Yes you should be able to use a ratchet shifter with a 2 inch body lift.
1981 CJ7 - 350TBI, sm465, np205, D60, 14bolt, 5.13s, detroits, 38.5 SX's 1998 Z71 extended cab 1998 Tahoe 2001 Tahoe LS - FOR SALE - $18,500 |
Thread Tools | |
Display Modes | |
