Old 06-10-2002, 02:42 PM   #1
Southpa
Southpa's Avatar
3/4 ton master cyl. in 1/2 ton truck?
Its nice to be home again, staying this time. I want to ask about swapping my master cylinder which is leaking out the cap so much that I have to hang a can under it to catch the "drippings".
Its a 1970 1/2 ton but I've swapped front ends with a 71 so now I have front disc brakes. I installed a 3/4 ton booster and have a 1/2 ton master (leaker) with the single hold-down clip. What I want to do is replace it with a 3/4 ton master (the kind with 2 hold down clips). Any problems with that? Are the line fittings to the prop. valve the same size? Would this produce too much pressure to my front calipers and/or rear wheel cylinders? or are all calipers/wheel cylinders basically the same between 3/4 and 1/2 tons? Any suggestions? much appreciated!
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 06-10-2002, 07:07 PM   #2
Mike C
Mike C's Avatar
The brake system is carefully engineered for the diameter of the pistons in the rear and in the front. You can get the 1/2 ton master with 2 hold downs. If you do run the 3/4 and I would not, the size of the fittings that screw into it are reversed, just so somebody WOULDN't do that
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-10-2002, 07:43 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Plus, out of the 3 trucks I have owned, which gives me 6 master cylinders to date, EVERY ONE leaked like that.
I've tried tightening the clip, but that never seems to help.
Old 06-10-2002, 08:45 PM   #4
1-PU70
1-PU70's Avatar
To get the cover from leaking with the master still on the truck remove some fluid from the master then stuff some rags in it. Take a pice of glass or flat pice of steel and sand the lip around the master till it is smoth. Should take care of any leaks.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 06-10-2002, 10:16 PM   #5
>X<
registered IWATA user
>X<'s Avatar
i'm kinda doin somethig like that,. i'm using discs from my 72 3/4ton on my 1/2 ton project, the people at early classic told me that i could ust the master cyllander if i wanted to, but if i put some rear discs on it i will have to change it anyway, if i use the discs from my 3/4 ton can i use that master cyllinder too?
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black
-'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end.
-01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny.
Take off that Von Dutch hat before i stab you with a 000 Mack.
>X< is offline   Reply With Quote
Thread Tools
Display Modes
