Old 06-10-2002, 04:56 PM   #1
Chevy409
Giddy up giddy up...
Chevy409's Avatar
Any mud fanatics? (I have a retard Q for ya)
I've seen some pretty cool mud rigs that have their radiators out back mounted in the bed to avoid the flying goo... but how do they get the water back to the engine? Is it just rubber hose routed all the way from the front to back, probably along the frame rail or something? Seems like that much hose just waiting to be slapped with a stick and in the open is asking for trouble. I'm prtetty interested though and appreciate any and all info on the subject. Thanks.
72 with 69 grille and custom 73-87 stepside. BIG BLOCK 409, SM465, NP205, 3/4 axles slung under a 5" lift, 3"bodylift, 112" frame, and 35inch Pro Comp X-terrains... "BUILT NOT BOUGHT" Here's the site...
Chevy409 is offline   Reply With Quote
Old 06-10-2002, 05:06 PM   #2
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
Yeah they run rubber line all the way back usually. Often times on nice nice rigs the tube has SS mesh around it to prevent cutting/gouging. others have special shields they put along the frame rail to prevent stuff from jabbing in there and such. lots of ways to do it i suppose.
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 06-10-2002, 05:29 PM   #3
Chevy409
Chevy409's Avatar
Hmm, cool. Sounds like it's sort of your own method rather than any special prcedure. The 409 has still been heating up a bit with the hot days lately and I have a monster radiator in the garage, this is why i ask. The guy i bought it from built it for a monster truck application but the guy who ordered it never came to pick it up and he let it go to me cheap... this thing doesn't fit under the hood though, too tall and too long. Be pretty sweet to lay across the bed though Thanks for the info.
Old 06-10-2002, 05:32 PM   #4
Chevy409
Chevy409's Avatar
Is there ever a problem of not being able to pull water from that far back and through so much pipe? Seems like a long way for the water pump to do all that work.
Old 06-10-2002, 05:59 PM   #5
lukecp
Formerly yellow72custom
lukecp's Avatar
I'm not building a mud truck...but i wonder if you could use PVC or metal pipe for the radiator lines.....it would be alot tougher than rubber the whole way.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 06-10-2002, 07:13 PM   #6
Chevy409
Chevy409's Avatar
Maybe a combination of rubber and PCV, now that sounds cool Still wondering how easily the water can travel though.
Old 06-10-2002, 08:04 PM   #7
Pont
I need another Barley Pop
Pont's Avatar
I have a friend that stuffed a BB in a Chevy Luv and had to mount the radiator in the bed with electric fans. He ran exhaust pipe along the frame to supply water from the radiator to the engine, then used rubber hose to hook it up. Seemed to work fine with nothing other than the stock water pump.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 06-10-2002, 08:28 PM   #8
Chevy409
Chevy409's Avatar
Nice, thanks for all the info guys, this may be an option for me in the near future.
Hey pont, do you have any pics of your truck bigger than that thumbnail by your name? That things looks awesome!
Old 06-10-2002, 09:25 PM   #9
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
http://communities.msn.com/68k10/67truckpictures.msnw pictures of ponts truck
68SWB4x4 is offline   Reply With Quote
Old 06-10-2002, 11:02 PM   #10
wbmorris87
Muffler Pipe
I race a street stock race car and I have the radiator in the back for damage/weight reasons. I used 1 1/2" muffler tubing bent and arranged nicely. The cool thing is you dont need to make any other changes. if you want to put an electric fan on it, use a 92 Ford Escort. They are a dual speed and also move the most air. if you got room run 2 of them. www.rattlesnakeraceway.com
Fallon, NV
wbmorris87 is offline   Reply With Quote
Old 06-11-2002, 01:41 AM   #11
Mudder
Mudder's Avatar
weight
most of the trucks u have seen this on dont run that long. mud pits. its good to get as much weight behind the tranny as u can, with all the engine wight there in the front. helps to have some weight on your traction gettin tires, especially if your pulling the front from those wicked hole shots it does help to keep muddy water out of the fins too, until the clods start dropping on it.
Mudder is offline   Reply With Quote
Thread Tools
Display Modes
