04-24-2005, 06:19 PM | #1 |
i love summertime
what size clutch do i need?
well the 71 left me stranded lastnight, the clutch went so i got it towed home today and next weekend she is getting a new clutch, and bearings. anyways i think the book shows 2 different sizes...11 and 12 inch i believe..what should i go with? its a 350/4spd set up
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
04-24-2005, 07:02 PM | #2 |
If you are going with a stock replacement, i would go 12" on the clutch....Centerforce, Hays, ect, go 11" . the same flywheel bolts either setup, but most of the high performance clutches will be 11".....69L
http://community.webshots.com/user/hotrodhorn |
04-24-2005, 07:43 PM | #3 |
i love summertime
what would last longer? this truck is my daily driver so i dont need perfomance or anything just reliability and for it to last long as possible
04-24-2005, 07:55 PM | #4 |
Sisyphus was my mentor!
I changed my clutch myself last summer & I got a 12" (i know I dont need a 12" but an 11" clutch was 160 so for 15 more bucks I got a killer clutch) OEM clutch (throwoutbearing, friction disc, pressureplate & alignment tool) for diesel GMC's for 175CDN from a local clutch shop & they ground my flywheel for that too, but it took 2 days & while I was there, I changed the rear main seal as well. I have a L-6 & a three-on-the-tree. Mione's a dailydriver too & my reasoning sez that a 12" would last longer. MANY high perf clutches are 11" - this is for less rotating weight & not necessarily durability.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
04-24-2005, 08:16 PM | #5 |
I agree, for a daily driver, the 12" stock replacement is a good deal. If you like to run hard off road, or race a little.....Centerforce dual friction is the way to go. it just depends on intended useage L
04-24-2005, 09:50 PM | #6 |
Still drivin' a Rat Rod
I'm running an 11" with the same combo,have no problems with slippage and ect.
I'm going to a twelve when I have to change it prolly.If you're not doing much tugging and towing an 11" will be fine.If it's just a few bucks more go for the 12.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
04-24-2005, 11:14 PM | #7 |
i love summertime
thanks guys
Thread Tools | |
Display Modes | |
