Old 04-26-2005, 03:26 AM   #1
teamradrz1
teamradrz1's Avatar
Drive shaft Question
My Blazer has 3/4 ton axle conversions with a 4" suspension lift and I believe the original drive shaft (slip style) anyone with a 4" lift replace their Drive shaft or were you able to stay with the original?
1971 Chevy Blazer CST 4X4
2012 Camaro 2SS/RS
2007 Avalanche 4X4
teamradrz1 is offline   Reply With Quote
Old 04-26-2005, 05:39 AM   #2
vtblazer
vtblazer's Avatar
I had my rear shaft lenthened some, can't remember the exact amount but I know it was worth doing. Sorry, it was several years ago...
Check to see how much spline you've got showing outside of the yolk, go from there.
O/T, take a minute to fill in your location/where your from.
Welcome to the board.
vtblazer is offline   Reply With Quote
Old 04-26-2005, 06:11 PM   #3
wingman
Mine with the lift has a double cardigan drive shaft and a small t-case drop but i dont know if the drive shaft is original.
wingman is offline   Reply With Quote
Old 04-26-2005, 06:35 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
2 THE BOARD FROM WEST 10-UH-C
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-26-2005, 07:52 PM   #5
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
First, welcome from Seattle.
From what I've read, a 4" lift is usually borderline for needing the drive shaft lengthened. Your 3/4 ton axles may have changed the dimensions and angles enought that it may be necessary. I don't think it is very expensive, and if you are going to be out 4x4ing, you might want a little more insurance so you don't get stuck out in the woods.
Post some pics of your rig when you get a chance. We all like to see pictures of new members Blazers!
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-26-2005, 09:28 PM   #6
teamradrz1
teamradrz1's Avatar
Thanks for the warm welcome everyone! I will get some pics up soon. I am almost at the paint stage for my truck I just put the engine back in it and gonna try and get her started tonight.
2012 Camaro 2SS/RS
2007 Avalanche 4X4
Old 04-27-2005, 02:24 AM   #7
teamradrz1
teamradrz1's Avatar
SUCCESS!!! After 2 years I am most excited to say IT'S ALIVE! got her running again tonite and she sounds awesome! I'll post some pics tomorrow.
2012 Camaro 2SS/RS
2007 Avalanche 4X4
Old 04-27-2005, 10:19 AM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
Congrats on getting her running - that is always a big step.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-27-2005, 11:37 AM   #9
bouncytruck
SKINNY TIRES RULE!
bouncytruck 1972 K5
Old 04-27-2005, 02:34 PM   #10
teamradrz1
teamradrz1's Avatar
Ok I finally got some pics
chevy 350 rebuilt with edelbrock cam and lifter set, Alum roller rockers, gear drives and Performer EPS permastar intake, edelbrock 600cfm (gonna try a 750cfm see if it's better might be to much).
then my new 2004 Acura leather heated elec seats I got for $450 for set
then my 2" suspension lift with new poly bushings
2012 Camaro 2SS/RS
2007 Avalanche 4X4
Old 04-27-2005, 03:01 PM   #11
bouncytruck
SKINNY TIRES RULE!
Looks nice. I like the seats!
bouncytruck 1972 K5
Old 04-27-2005, 06:13 PM   #12
audioholic
I admit Im new to this stuff so I may be wrong, but that's a body lift, not a suspension lift... right?
That motor looks sweet.
audioholic is offline   Reply With Quote
Old 04-27-2005, 07:17 PM   #13
teamradrz1
teamradrz1's Avatar
Yes that pic is of the 2" body lift. I do have a 4" suspension lift as well. My bad I see I typed it wrong I was in a hurry.
2012 Camaro 2SS/RS
2007 Avalanche 4X4
Old 04-27-2005, 08:43 PM   #14
Scrubby
Check out GMTrucks.org
I stayed 1/2 ton with a 4 inch lift and had to have both my front and rear shafts lengthened. The guy rebuild the CV in the front, balanced, and put in all new spicer joints also and it was under $300.
Scrubby is offline   Reply With Quote
Old 04-28-2005, 04:23 AM   #15
LeRoy
Registered truck nut
LeRoy's Avatar
I ran my stock drive shaft for years with a 4" lift. Then went 3/4 ton running gear and had a new driveshaft made that'll hold the bigger u-joint without buying the conversion u-joint. The driveshaft is the same diameter and as strong as the 1 ton version. Now my K5 is sitting on 11" of total lift, 1 ton running gear and I'm in the market for a longer driveline. I'm going to have to have HIGH ANGLE DRIVELINE make me a new one with double universal joints. You can have my old one for $100 plus shipping. I say it has less then 5K miles on it
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Thread Tools
Display Modes
