How do I Tighten Chrome Ignition Bezel?
I finger tightened the chrome ignition bezel in the dash and it seems seated all the way, but if i reach around, the ignition switch housing is loose.
Without the special tool, how do i tighten that bezel more...........screwdrivers would scratch both the bezel and dash if i slipped........any other thoughts? Gordon |
More Cowbell....
I think you just answered your own question. I had to order the 'special' tool.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
Post Whore
![]() Join Date: Feb 2000
I just tightened mine by hand - Putter, what is the special tool?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
67-72 Addict!
To give you an idea, here is a pic showing how the 3 studs in the tool would line up with the indentations in the bezel allowing you to tighten. I just grabbed this off the net:http://www.impalaparts.com/customer/...cat=472&page=1
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Thx for the pic, i think a taped up big screwdriver might do the trick, for $10 plus shipping there are a lot more useful tools! Mine got 80% tight by hand and just stopped tightening......i'll fiddle..........thx for the responses!
Lovin' Life in Miss.!
Eric, you have a link for that bezel tool? Dunno if that Impala one will fit our trucks.
The truck... you hear that? No really, you did hear that?!!! |
67-72 Addict!
I was just showing what it looks like. Our board vendors probably sell the ones for our trucks. I did what 72c5 said about the screwdriver!
That's how I installed mine. ...I just have a thing for tools.
Edit: And old tech manuals and old parts books and old owners manuals and...
The truck... you hear that? No really, you did hear that?!!! Last edited by chickenwing; 04-27-2005 at 01:16 PM. |
I have a "Special" tool for this purpose. I took my old bezel to work and had my machinist make me an installation tool. I thought he would get the lathe and milling machine going for this. But, he just took a piece of pipe and cut three notches around it and inserted some roll pins (in the right locations) and then "Electrical-Taped" the pins in place. It works like a charm! I'll look for it tonight and take some pictures of it (if I can find it). If someone can help me post them, I'll e-mail them. It really is a simple solution and it was free!
T |
SKINNY TIRES RULE!
LMC lists the tool for $8. I used a piece of wood cut to a point on the end and tapped the other end with a hammer. Worked ok. I didn't want to wait to get the tool.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Its Magically Delicious
you can also use a pair of needle nose pliars pryed open into those slots ... then turn carefully ..if your not care you'll slip and scratch your dash ..like i did
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
More Cowbell....
Yep, that is the tool I am talking about. Only gave 8 bucks for mine also, but got it from a different dealer....(Thetrucksandcarshop). Would be pretty easy to duplicate it once you have the correct measurements.
#13 |
Definitely try the needle nose pliers. I have used them a number of times, and as long as you go slowly and keep the pliers in place it will work as good as any specialty tool.
'72 Chevy Suburban Custom Deluxe 10, 402/TH400 |
#14 |
thanks, great idea, needle nose clamped in a vice grip! with a very firm hand!
Thread Tools | |
Display Modes | |
