Old 05-01-2005, 02:30 PM   #1
72MARIO
72MARIO's Avatar
Silicone Brake Fluid.... Should I use it ?
I just bought my new master Cyl for manual brakes. I am going to spray it torch red just like the fire wall. I dont want the brake fluid to peal the paint off my firewall and MC. So I have been told about Silicone. Is it oky to use in these systems ??
I have all new brake Stainless 20 straight lengths coming this Friday. The entire system is dry and brand new.
Let me know you thoughts.
Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 05-01-2005, 03:09 PM   #2
zeeklu
As long as the wheel cylinders and calipers are clean you won't have any problems. I've used it in my 67 k10 for 5 or 6 years with no side effects at all.
Just pour it in slow ,don't shake the bottle, pump the pedal slowly when bleeding and you will be good to go. I usually open all the bleeders and fill the system and let it gravity bleed before I start the regular bleeding routine. Chris
zeeklu is offline   Reply With Quote
Old 05-01-2005, 03:51 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I lost the link, maybe some one here still has it, but silicone isn't a good idea for a driver.
Acording to the articles I've read on it, it is actually a BAD idea for a driver...better suited for a race car or a trailer queen.
Old 05-01-2005, 04:02 PM   #4
zeeklu
I've had it in my driver for 5 or 6 years and 50K miles but that doesn't mean my results are the norm. Chris
Old 05-01-2005, 04:03 PM   #5
Gee_Emm
Silcone fluid is perfectly fine to use. The only problem is that you would have to get ALL of your old fluid out, and then flush the system before changing over. If you are using all new parts then you are good to go. Silicone has great advantages like not absorbing water from the air, not eating paint and better heat capabilties.
Gee_Emm is offline   Reply With Quote
Old 05-01-2005, 04:10 PM   #6
zeeklu
But supposedly it does hold air bubbles longer than regular brake fluid but I didn't have any problems. The nice thing is how clean the system stays. You can take the lid off the mastercylinder and still see the ports in the bottom through the silicone fluid like you were looking through water. Chris
Old 05-01-2005, 05:28 PM   #7
ratrod67
ratrod67's Avatar
I run the silicone fluid in all my older cars. Haven't had any problems yet. I've heard of a lot of people not getting as firm of a pedal with the silicone but I think it's because they haven't gotten the system bled well enough.
ratrod67 is offline   Reply With Quote
Old 05-01-2005, 06:44 PM   #8
RON WOODGEARD
Resident Young Old Dude !
I've ran Silicone for over twenty years... It's been in this truck for 18....
Just be sure as you typed "ALL" of the other is out of the System, they are NOT compatible whatsoever...
It comes FACTORY in many vehicles..It is not bad as long as the changeover is done correctly.
Replace or clean with alchohol every rubber part in the system, and as I already typed, ALL of the old stuff HAS to be OUT...
RON WOODGEARD is offline   Reply With Quote
Old 05-01-2005, 09:58 PM   #9
Longhorn Man
One thing i remember is that since the sillicone stuff doesn't absorb water, the water that gets in there from normal humidity/condencation doesn't mix and sinks to the lowest point of the system and rusts the lines from the inside out.
Old 05-01-2005, 10:42 PM   #10
mocwon
Keep On Truckin'
mocwon's Avatar
Stainless lines like Mario is getting should not rust.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 05-01-2005, 11:21 PM   #11
72MARIO
72MARIO's Avatar
Oky,
Sounds Good.
I checked into pricing it's a bit more but if I have to get the inner fender resprayed the paint is going to be more than the diffirence in cost between regular and silicone brake fluid. I am going to pick some up when I get the lines.
Thanks for the help.
Mario
2005 TAHOE DD
Old 05-02-2005, 01:51 AM   #12
4x4Poet
Consider synthetic DOT 3 or 4 fluid. I was in Checker, of all parts places, and they had Valvoline synthetic brake fluid for sale. A little more costly than petro brake fluid, but the synthetic is compatible with petro fluid, so I can use it without having to start with a clean, dry system and can use any DOT 3 or 4 fluid with it, say if I'm unable to find synthetic. The synthetic should not break down as easily as petro fluid. For our street driven trucks, I think these advantages outweigh any of silicone fluid's advantages, namely the ability to handle high heat IIRC.
Interesting, LM. I never thought of that possibility. Not that it matters since I'll probably never use silicone brake fluid.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 05-03-2005, 06:04 AM   #13
RON WOODGEARD
It'll work..
Old 05-03-2005, 05:16 PM   #14
zeeklu
If the system is full to the top and the rubber diaphram in the lid is against the top of the fluid where would the condensation come from? Chris
Old 05-03-2005, 07:02 PM   #15
BurnoutNova
BurnoutNova's Avatar
dot 5 costs about 4x what normal dot3 costs, but your ENTIRE system ptobobly only holds 1qt at the most.
i'd go with it if all my stuff were new.
BurnoutNova is offline   Reply With Quote
Old 05-03-2005, 08:51 PM   #16
Longhorn Man
zeeklu, water will get in there. no matter what you do, it will get in.
When you depress the pedal, fluid is forced through the lines...somethign has to take the space where the fluid once was...in the resivour. Air will move in. Air with humidity.
Plus, if you have it that full, then you have it overfilled anyways.
Old 05-03-2005, 08:56 PM   #17
tom hand
CCRider
tom hand's Avatar
The only problem you will have with it if changed over properly, is that is doesn't work well at high altitudes...somthing to do with the boiling point. If you go to really high altitude you will have a spongy pedal and there is nothing you can do about it...at sea level you will have no problems and it will save the paint
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 05-03-2005, 08:58 PM   #18
724wdcopper
graphic designer
724wdcopper's Avatar
isnt that where the rubber bladders in the MC lid come in? they fill with the incoming air, preventing it from mixing with the fluid? of course, like you, i believe some air WILL eventually enter the system from one source or another. but it will with regular brake fluid, too, so i dont see a whole lot of difference. how often does everyone check their brake fluid level? i for one have probably neglected it more than i've monitored it. whichever way you go, proper maintenence would be the key.
724wdcopper is offline   Reply With Quote
Old 05-03-2005, 09:29 PM   #19
BubbaGreen
Hey folks, this is an interesting subject....I replaced the DOT3 fluid in my '86 mustang when it was new...then I read the manual where it stated "DONT USE SILICONE" brake fluid. Well, lets just say, its been in there for almost 20yrs now. I have had absolutely no issues with the brakes, its not a daily driver, but I do have 80K on the car now and I have owned it since new.
Thing is, I am almost done doing a frame off resto on my 71 truck, and purchased a new master cylinder from master power brakes (the power assist version) and all new components, ie, calipers, rear cylinders, prop-valve, and all sst lines. But have been thinking the DOT4 Valvoline brake fluid over silicone. MasterpowerBrakes states they will instantly void the lifetime warranty if silicone fluid is used and I am not really sure why. Original DOT3 fluid just bites the bullet, it ruins paint with no advantages. DOT4 seems to just cost more and still it eats paint...DOT5 seems like the cats meow, but it cost more and for some reason, manufactures say to avoid it....uhm....
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 05-03-2005, 09:55 PM   #20
mr402
I haven't heard too much about the synthetic brake fluid. Is it any better as far as not eating paint? 4X4 what was your experience with it?
I went to silicone fluid in my 62 Impala a good 15+ years ago. I have had no brake issues since that time. I know that with any other fluid I would have had to rebuild the wheel cylinders at least once or twice in the same time period. Main reason I did was because it's a garage queen. I rebuilt the wheel cylinders when I first got it and 3 years later they needed them again. At that point I redid everything and tried the silicone fluid and haven't looked back since.
Enjoying life again. Time to get those big blocks rolling.
mr402 is offline   Reply With Quote
Old 05-03-2005, 09:56 PM   #21
neonlarry
neonlarry's Avatar
DOT 3 & 4 absorb water DOT 5 does not, like Andy said that water (and there will be water eventually) sits next to your metal parts and rusts. The real advantage of DOT 5 is increased boiling point, this is a real advantage in race cars. But race cars usually have their fliud changed after every race so water buildup is not a problem. All I can say about leaving the same brake fluid in your car for 20yrs is how long do you leave your oil in? Brake fluid should be changed about as often as antifreeze, every year.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-03-2005, 10:15 PM   #22
RON WOODGEARD
Neon, You're absolutely right about changing the Fluid, But it's like the tranny fluid, it's something that unfortunately gets skipped over as a Maintenance issue....
I've changed the brake fluid in my truck, every other year in the last 18 years.... Tranny Fluid every year. Along with the Rear end fluid, and Anti-Freeze...
Old 05-03-2005, 10:19 PM   #23
Canadian72GMC
Well, here goes. Silicone brake fluid and regular DOT 3 or 4 will not mix. They will stay separated. I would not waste time cleaning out the system to change to one or the other though. They will not harm one another. DOT 3 and 4 are hydroscopic. They absorb water. This feature is essential in a brake system. Brake fluid will absorb moisture through the bladder in the m/c, through brake hoses, and simply from removing the lid, at the rate of about 1% per year on average. It can absorb up to about 3% of it's volume.2% moisture will reduce the boiling point of brake fluid almost by half. Not normally a problem unless you do severe braking(mountain driving etc). Boiling brake fluid is just that-liquid to gas, gas is compressible = no brakes. Brake fluid for that reason alone should be changed every 2 years. Silicone brake fluid (DOT 5), as previously mentioned, does not absorb water. Water will migrate to lower areas in the brake system, typically wheel cylinders and calipers, causing rust and brake problems.It does however have a higher boiling point. DO NOT USE SILICONE BRAKE FLUID IN BRAKE SYSTEMS WITH ABS. Yes, I was yelling. There are very finely machined electronic valves and actuators in all ABS systems(expensive) that will not tolerate ANY moisture or rust.
Canadian72GMC is offline   Reply With Quote
Old 05-03-2005, 10:38 PM   #24
72MARIO
72MARIO's Avatar
Oky, So am I stil good to go with the silicone ? Just change it every 2 years ?
2005 TAHOE DD
Old 05-03-2005, 10:44 PM   #25
mr402
I actually just bleed it every few years. Like they said, moisture tends to travel to the bottom.
Thread Tools
Display Modes
