Old 05-01-2005, 07:38 PM   #1
Faster_than_you
69 grille on 71.
I was wondering if it is possible, o.k. wrong words- you can fabricate anything to make it work.
Is it possible to interchange a 69 chevy's grille directly with a 71 chevy?
thanks
~Christopher L. Orr
71 c20, 454- Stolen While Deployed. dynoed at 550 ft lbs, 425 hp at 3000 rpm (mustang dyno). TH400 3500 stall.... etc, etc.
Faster_than_you is offline   Reply With Quote
Old 05-01-2005, 08:08 PM   #2
Hart_Rod
Hart_Rod's Avatar
I believe it should be a straight swap as long as you are changing both the inner and outer grill.
Hart_Rod is offline   Reply With Quote
Old 05-01-2005, 08:08 PM   #3
Gee_Emm
It will bolt right up. You just have to deal with the extra holes in your bumper and you will need a new wiring harness.
Gee_Emm is offline   Reply With Quote
Old 05-01-2005, 09:49 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The hood release on the 71 72 sticks out a bit more. you'll have to bust out some space in the upper center of the inner grill in order to do this.
The one ton longhorn i have was like this when i got it...71/72 front sheet metal with a 69 grill. I have pics somewhere...
Old 05-01-2005, 09:56 PM   #5
Longhorn Man
Hwew you go...same front sheet metal (except the hood) placed on my old truck. I had to lighten it quite a bit, but you can see the hood release poking out.
Old 05-01-2005, 10:00 PM   #6
Randy70C-10
Randy70C-10's Avatar
It's a direct swap but for it to be a perfect swap you also need the change the grill support and hood latch assembly. I might have a hood latch assembly that you can have, I'll have to look around.
Randy70C-10 is offline   Reply With Quote
Old 05-04-2005, 07:37 PM   #7
Faster_than_you
Thanks y'all for the input!
~Christopher L. Orr
Thread Tools
Display Modes
