05-02-2005, 07:56 PM | #1 |
PROJECT 7DEUCE
Need u-bolt help...
Can someone go out and measure there stock blazer rear u-bolt's I need lenght-width- and diamater thanks in advance Luke..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-03-2005, 07:17 PM | #2 |
PROJECT 7DEUCE
T.t.t.
05-03-2005, 07:49 PM | #3 |
U-bolt measurements, Blazer rear with (5) leafs in the spring stack.
Thread diameter 5/8 fine thread, total length 19" (18" would work if 19" is not available). Shank diameter, (rod diameter) .587". Inside width between the legs is 2 3/4". Jim |
05-04-2005, 09:40 PM | #4 |
PROJECT 7DEUCE
Damn jim you are a wealth of knowledge thnk you.... I don't suppose you know the front u-bolts????
Thread Tools | |
Display Modes | |
