Old 05-05-2005, 06:05 PM   #1
robertwb
dana 44 wheel bearing nut spanner socket?
I'm trying to get the hub/rotor off to replace the ball joints-I have the 4 prong tool that gets the lock nut off and right behind that is a round nut with holes around it-looks like there is probably another tool that removes this nut-I tried the punch and hammer and it wouldn't budge and I don't want to screw it up
can someone confirm that there is a special tool for this and where to get one? everywhere in town here says the 4 prong one is the only tool...obviously there's more
robert
1972 LWB 4x4
1970 LWB 2wd
1971 chevelle
1972 datsun PL-521/nissan
robertwb is offline   Reply With Quote
Old 05-05-2005, 06:44 PM   #2
drink2mny
drink2mny's Avatar
You have an outer lock nut that you already took off.
Then there is a washer with holes and a tab so it sits in the groove in the spindle.
Use 2 small screw drivers or something "L" shaped to get behind it, then slide it out..
then you will have another nut too use your socket on.
Take that out and you should be good..
Hope this helps
Support The Board
drink2mny is offline   Reply With Quote
Old 05-05-2005, 10:31 PM   #3
robertwb
thanks -I finally got it
there was no washer with a tab like usual-it was a round washer with holes and there was a pin in the rear nut that kept it from turning so it didn't act like a washer and it didn't want to come off either...but it did
then I got to fight with the steering arm tapered things...that was fun
but I should've known on a 33 year old truck thats never been taken apart
robert
1972 LWB 4x4
1970 LWB 2wd
1971 chevelle
Old 05-05-2005, 11:01 PM   #4
drink2mny
drink2mny's Avatar
Good.. Glad you got it..
Yeah I did forget to add the pin through the holes deal
Have fun
Support The Board
Old 05-05-2005, 11:40 PM   #5
Budweis
Geared for Collision
Budweis's Avatar
hit on the side of steering arm right toward studs and pops right off like a spring i found out after a hell of a time with mine.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB
1970 C/K20 3/4 Ton
1996 Collectors Edition Corvette
1977 Corvette Coupe
Budweis is offline   Reply With Quote
Thread Tools
Display Modes
