Old 05-05-2005, 06:58 PM   #1
454HO
converting from 1-1/4" to 1" rotors
I am considering changing the front brake rotors on my '77 to the later 1" thick ones in order to use the BelTech spindles I already have. Am I for doing this? Are the 1-1/4" brakes significantly better? Should I spend the $280 and get the right spindles? Anyone have a set they would trade?
- Greg
454HO is offline   Reply With Quote
Old 05-05-2005, 07:42 PM   #2
jermasaurus
jermasaurus's Avatar
I have 1 1/4" and can stop nicely, I can't really compare to the 1" rotors though. It is considered the heavy duty option for the breaks so somthings gotta be better. Possibly at dissipating heat.
Instead of spending $280 in spindles, you can spend $220 for DJM's 3" spindles.
jermasaurus is offline   Reply With Quote
Old 05-06-2005, 08:50 AM   #3
beaterC10
I converted to 1 1/4" rotors from 1" when I installed drop spindles. I noticed some difference, but not a huge amount. The worst part of the deal is the cost, you will have to replace rotors, inner and outer wheel bearings, and calipers. I also replaced the brake hoses and pads, because they were shot.
beaterC10 is offline   Reply With Quote
Old 05-06-2005, 12:36 PM   #4
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
Why not sell your spindles and buy the correct ones for the 1 1/4's.
I can't see spending money to downgrade your brakes just to look cool.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 05-06-2005, 12:55 PM   #5
bigblock73
yeller
bigblock73's Avatar
I would personally keep the bigger rotors and buy the right spindles. Sell the other spindles, either here or on Ebay. You may lose a little money on the deal (maybe, but maybe not), but with a big block and the possibility of using it for towing...keep the bigger brakes.
bigblock73 is offline   Reply With Quote
Old 05-06-2005, 01:19 PM   #6
bodydropped
im fixin to go from 1 inch on my 78 to 1 1/4 and i have all the stuff i need to do the change over i got a 82 with 20,xxx miles so i got some basically new frt end to swap
bodydropped is offline   Reply With Quote
Old 05-06-2005, 07:11 PM   #7
454HO
Thanks for the feedback. I'm going to follow y'alls advice and stick with the 1-1/4" rotors.
- Greg
Thread Tools
Display Modes
