Old 05-08-2005, 10:01 PM   #1
weekender
Talking Gearing Up
I've got a 83 dualy that I just finished up and it has a 454 with the old standard three speed with low, I havn't looked to see what the gear ratio is in the rear but it is to low, has anyone know how or what I can do to change the gear ratio in the rear, what would work? I wish I had another gear to go into. You guys with the one tons know what I mean. Got it all together, now I can't aford to drive it. Any ideas.
Jim
weekender is offline   Reply With Quote
Old 05-08-2005, 10:48 PM   #2
edog1
edog1's Avatar
Do you plan doing much towing with you truck ?
edog1 is offline   Reply With Quote
Old 05-09-2005, 11:19 PM   #3
weekender
I pull a fifth wheel camper but I have enough motor to do the job. I use to pull it with a 350 motor so this 454 should do ok even with a higher rearend.
Old 05-10-2005, 12:42 AM   #4
u2slow
Web Wheeler
u2slow's Avatar
Dana 70 gears are easy to come by. Most likely 4.10 or 4.56 in your 1-ton. 3.54 should be considerable improvement.
'66 C10 longstep - Clifford equiped
'84 C20 Suburban 6.2L - awaiting 4x4 conversion
'91 V3500 Crewcab - awaiting diesel swap
u2slow is offline   Reply With Quote
Old 05-10-2005, 01:46 AM   #5
1FaastC10
1FaastC10's Avatar
most likely they're 4.56s. i wouldnt go any lower than 4.10 if you're using it to pull a trailer of any weight, which a 5er is of considerable weight, or it would be bumper pull. 3.54s are a hideous idea, i wouldnt even consider a gear like that on any truck that if they werent in it from the factory.
1FaastC10 is offline   Reply With Quote
Old 05-10-2005, 02:14 PM   #6
TRUCKGUY
TRUCKGUY's Avatar
i got 3.20's and they do great!!!...............later
Dan.
55 F100 panel truck project
64 350/th400/10bolt short fleet
66 F100 302/C6/9" short fleet
67 IH 4x2 304/t984speed D44 373 locker lwb box
67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box
67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt
81 2wd short fleet current build!
83 350/700r4 short fleet
88 k5 12" lift 3/4 ton swap mud toy
96 Dodge 3500 CUMMINS/5speed/4x2
97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops
TRUCKGUY is offline   Reply With Quote
Old 05-13-2005, 09:02 PM   #7
weekender
Sorry it took so long to get back,in my line of work we are realy busy right now. I like the idea of the 4:10's What truck do you think would have them allready under it, I would rather change the whole rearend then rebuild the whole rearend.
Thread Tools
Display Modes
