05-09-2005, 04:53 PM | #1 |
Rear End Gear Ratio
I know this has been covered before, but can't find any history. I am trying to figure out what gear ratio my "72 C10 has. I was told it is supposedly a 3:73. I tried the jack up both rear tires and rotate the tire then count the rotation of the pinion yolk. I came up with 1.5 turns of the pinion to 1 full tire revolution. Some how this doesn't sound right. What ratio would this be?
Thanks Don
Thanks Don '57 Chevy Nomad '70 Buick GSX '72 Cheyene (Boys' truck) |
05-09-2005, 05:49 PM | #2 |
turn the tire 2 time to get your number, 3 3/4 turns would be the 3:73 gears.
good luck |
05-09-2005, 11:05 PM | #3 |
I bet it is a 3.07 in a 72 if it is a factory V8 truck. And I bet it is actually just over 1.5 turns on the pinion to a full revolution on the tire.
Mark
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
05-09-2005, 11:10 PM | #4 |
If you don't have posi, keep one of the tires stationary. This will give you the actual ratio. You will most likely have three and a half or three and three quarter turns....3.42 or 3.73.
69 SWB LT1/4L60E www.classicplace.com |
05-10-2005, 12:19 AM | #5 |
If you have a "peggleg", & 1 wheel on the ground, i will bet 3.07 as Hotfun has stated. The ratio on the spiders is 2 to 1...... L
http://community.webshots.com/user/hotrodhorn |
05-10-2005, 12:32 AM | #6 |
why don`t you get the code off of the tube on passenger side.this will tell you ratio,what it was originally to be put/installed in at factory.or,better yet,take off the cover(no telling how long gear oil has been in there)and count the teeth on ring gear/pinion,divide pinion into ring,wala!or if you look on the side of ring gear while turning,it`ll be stamped into it with teeth count of both.good luck
Thread Tools | |
Display Modes | |
