05-11-2005, 04:44 PM | #1 |
Trans Transfer Mount
I have a 69 K-20 and the only mount for the trans to crossmember is the one under the adapter between the 2 gearboxes. ( Rubber cushion mount).
Should there be anything else for mounts to the transfercase maybe?? The truck only has the side mount motor mounts towareds the front of engine and not the bell mounts like some 2x trucks have. Thanks, Dave |
05-11-2005, 04:44 PM | #2 |
Any pics.?????
05-11-2005, 10:39 PM | #3 |
What about the side mount on the t-case that goes to the frame rail?
05-12-2005, 12:12 AM | #4 |
You need a set up like this....newer model transfer cases of the NP205 didnt have the holes in them to use this mount.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
05-12-2005, 02:11 AM | #5 |
Here is one from a 72 (if you look past the grease!)
05-12-2005, 08:56 AM | #6 |
My truck has a 205 transplant so I guess I need a set up as shown. The transfercase I have has holes but needs to be tapped out,, ( I assume)??? It figures there should be something there.
Dave |
05-13-2005, 03:08 AM | #7 |
Brackets should abound in good size junkyards. The torque bushings and tranny xmember rubber mounts are even available in poly from Energy Suspension.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
05-14-2005, 12:17 PM | #8 |
The crossmember looks different than mine. I guess because it had the Rockwell 221 transfer. It mounts to the bottom frame rail. Oh well, a little fab work and I should have it.
Thanks, Dave |
05-15-2005, 06:54 AM | #9 |
If you're using the stock trans-to-NP205 adapter, you could pick up a wrecking yard crossmember from an NP205 equipped 6?-72 GM 4x4. Should be able to get one on the cheap, since they're not rare items.
05-15-2005, 09:41 AM | #10 |
The crossmember that was underneath my 465/221 was reused with the NP205. Just had to move it back a few inches. Not sure if they are the same, but it worked just fine. My Rockwell also had a torque mount on the frame that I am going to reuse with the 205, it looks identical to the NP205 version.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 Last edited by 1969 GMC; 05-15-2005 at 09:43 AM. |
05-20-2005, 05:29 AM | #11 |
Tony "Life is a Team Sport" To the memory of the Hendrick Motorsports Plane Crash Victims |
05-20-2005, 06:20 PM | #12 |
I can't believe that e- bay price!! Ifound the same thing for 10 at the first yard I tried!!!
05-21-2005, 04:19 AM | #13 |
Haha! And the winner "might want to replace bushings!"
Thread Tools | |
Display Modes | |
