Old 05-12-2005, 03:56 AM   #1
apstguy
LED King
apstguy's Avatar
Brake booster failure
Recently, my brake have acted funny. Sometimes the brakes feel like they loose the power and become manual brakes. Sometimes it is hard to push the first half, then it acts as the booster kicked in and it is easy to press the brake the last half. Is this a power booster failure or did the one-way vaccum valve fail?
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 05-12-2005, 09:47 AM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Have you made a camshaft change to a more aggressive profile lately? Larger cams create less vacumme, and after you have the brake depressed for a short ammount of time the engine vacumme may just be building up. With the engine off for a few minutes, depress the brake and see if you still have any assist. If not you must either have a vacumme leak through the check valve or the grommet arround it, or a leak in the diaphram itself.
NeCrOmAnCeR is offline   Reply With Quote
Old 05-12-2005, 12:17 PM   #3
bigblock73
yeller
bigblock73's Avatar
Have you read Mikes article?
http://www.73-87.com/7387garage/chas...on/booster.htm
bigblock73 is offline   Reply With Quote
Old 05-13-2005, 03:48 AM   #4
apstguy
LED King
apstguy's Avatar
No I haven't changed anything. I have tested the booster as it says, but it checks out. Maybe I have a vacuum leak elsewhere?
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Thread Tools
Display Modes
