05-12-2005, 06:48 PM | #1 |
What does it take to make this work?
What work needs to be done (cutting, welding, relocating, etc) to get a 1973 or newer 12bolt rear end into a 1969 Chevy K5 Blazer? I know one shock mount needs to be relocated, but what else? BTW, this is for a leaf spring suspension.
I'm trying to determine if it's better to go with a '73+ rear end and have work done on it, or spend more time trying to located a correct 63' to 69' rear end. 73's and newer are a dime a dozen, but it's hard trying to find a drop-in rear end. Anybody have any knowledge on this? Thanks!
1969 K5 Blazer CST Always waiting for the Puget Sound sun..... |
05-12-2005, 07:45 PM | #2 |
user # 2756
The spring perches are wider by a couple inches so they have to be moved. The only newer (73+) that will work is a 1 ton 14 bolt which is only 1/2" different from a 72 and earlier rear.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
Thread Tools | |
Display Modes | |
