Old 05-24-2005, 07:31 AM   #1
Tink
Tink's Avatar
Adapter for NP203 to 700R4?
I am looking at putting a 700R4 in my 76 K5 (TH350 w/ NP203-still full time 4wd)... I have found the kit from Advance Adapters for this... PART # 50-6900, CUSTOM SHORT OUTPUT SHAFT, USE WHEN SWAPING A TH350 FOR A 700R-4 TRANSMISSION.
Has anyone used this kit? Do you still have to shorten the rear driveshaft since I believe the 700R4 is longer than the TH350?
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 05-24-2005, 09:15 AM   #2
smokekiki
Mike
smokekiki's Avatar
It all depends.It is 1.75" longer.With the 4" lift on my truck,I would have enough slip joint to let the driveshaft to be used.You need to move the transfer,or move the engine.Your front driveshaft might need to be lengthened.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Thread Tools
Display Modes
