Old 05-24-2005, 08:37 AM   #1
cysko9
MI '69
cysko9's Avatar
Trailing Arm Bushings
Anyone Have Any Good Ideas For Getting The Old Bushings Out Of The Trailing Arms??? Can't Seem To Just Pound Mine Out...
1967 Chevy (Project Frankenstein)
1973 K5 Blazer
cysko9 is offline   Reply With Quote
Old 05-24-2005, 08:45 AM   #2
mac
Active Member
mac's Avatar
Knock the sleeve out first. Use a hacksaw blade to cut each bushing into 4 pieces and work each piece out. They're stuck from old age and it took some time. The new poly bushings with new hardware make a definate difference.
mac is offline   Reply With Quote
Old 05-24-2005, 10:58 AM   #3
454HO
I always use a propane torch to heat up the outer shell of the bushing. Then press the inner sleeve and the rubber bushing out. Once the rubber is removed, I cut or crush the outer shell and then it pops out pretty easy. If you are replacing with Poly, some of them re-use the original outer bushing shell.
- Greg
454HO is offline   Reply With Quote
Old 05-24-2005, 11:51 AM   #4
DM310
I just drilled mine out
66 C10 (under construction)
1.5" crossmember drop
2" Z'ed frame
8" rear notch
Watts-link
Bagged
DJM 3" spindles
DM310 is offline   Reply With Quote
Old 05-24-2005, 12:02 PM   #5
Shane
Shane's Avatar
I took my trailing arms off and pressed them out with a hydraulic press. You put enough pressure on anything and eventually it will move.
Shane is offline   Reply With Quote
Old 05-25-2005, 12:45 AM   #6
cysko9
MI '69
cysko9's Avatar
ok... outer shell, inner shell, rubber...???? i only saw the inner metal sleeve and then the rubber that surrounds that... is there a third part to this thing?
I can get ahold of a hydraulic press so i'll go that route i think
thanks
1973 K5 Blazer
Old 05-25-2005, 02:09 AM   #7
1971 Cheyenne
1971 Cheyenne's Avatar
a press would really be the way to do it. I prolly messed with mine for 8 hours with a little torch, knives, drills, hammers, vices, etc, eventually just a little bit of elbow grease got em out. good luck
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 05-25-2005, 11:24 AM   #8
68LSS1
68LSS1's Avatar
thanks
Yes, there is a outer shell or metal sleeve that looks like it is part of the trailing arm but is actually part of the bushing. If you are using poly bushings you have to reuse that so you can leave it it the trailing arm.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 05-25-2005, 02:08 PM   #9
cysko9
MI '69
cysko9's Avatar
alright,
thanks
that piece that looks like the arm is what i was refering to i think
1973 K5 Blazer
Old 05-27-2005, 08:57 AM   #10
cysko9
MI '69
cysko9's Avatar
yah, so i tried pressing the things out last night.... and all i accomplished was bending the things.....
any suggestions? is there a particular was to press them?
1973 K5 Blazer
Old 06-06-2005, 01:31 AM   #11
bigjimzlll
bigjimzlll's Avatar
just use the hot wrench..get it smokin and tap them out
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 06-06-2005, 03:19 PM   #12
XXL
Seņor Member
XXL's Avatar
XXL is offline   Reply With Quote
Old 08-03-2005, 08:10 PM   #13
cysko9
MI '69
cysko9's Avatar
ok, time to drag this post back out..... what is the best way to get new rubber bushings back in?
1973 K5 Blazer
Old 08-04-2005, 03:13 AM   #14
68LSS1
68LSS1's Avatar
With either a press, a balljoint press or a big C clamp with a couple of pieces of thin aluminum or metal. Actually, they go in quite easily with a C clamp.
'68 Short Step
Old 08-04-2005, 07:22 AM   #15
Joe67
67 is sold
I used a propane tourch to heat up the outer sleeve and burn the top of the bushing then they came right out with a piece of wood and a mallet behind them.
I didn't remove my outers, just the inner and bushing itself.
took just a few minutes
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 08-04-2005, 07:38 AM   #16
cysko9
MI '69
cysko9's Avatar
How did you position the aluminum pieces? Inside the two forks of the arm?
1973 K5 Blazer
Old 08-08-2005, 08:36 AM   #17
Joe67
67 is sold
Are you trying to remove the inner and outer bushings?
The outers are a PITA, the inners come right out with some heat
Old 08-08-2005, 08:43 AM   #18
cysko9
MI '69
cysko9's Avatar
no, ive got the old ones out. im trying to put the new ones in... no biggy though, i'm headed to a napa today at lunch. id press them in at work with our hyd. press but i don't have anything to keep the forks from bending together (and they are already a little squished from trying to press the old ones out....
1973 K5 Blazer
Old 08-08-2005, 09:03 AM   #19
Joe67
67 is sold
Sounds like you are installing new outer bushings. I re-used my originals. I had no choice since my poly bushings come with inners only. It sounds like the easier way to go anyway.
Thread Tools
Display Modes
