Old 05-30-2005, 01:41 AM   #1
Sweet72k5
Sweet72k5's Avatar
Want to see some pics of 69-72 blazers with big blocks!!
I just wanted to see some pics of the engine compartment with the big block in and what mods where made with the fire wall!!!
Sweet72k5 is offline   Reply With Quote
Old 05-30-2005, 10:19 AM   #2
6772king
6772king's Avatar
here's mine I didnt do anything to my firewall ,,,I just moved everything up
67 chevy short step 2wd 427
71 chevy short fleet 4x4 396
72 gmc jimmy 2wd 377
71 chevy blazer 4x4 454
69 chevy longhorn 5.9l cummins
72 chevy 400 2wd custom camper
67 chevy lwb 4x4 454-in pieces
67 chevy panel soon 4x4-400
67 gmc dump 4x4 1 ton-305 WTF!!
72 chevy 3/4 ton 4x4 burb 350
70 chevy panel 2wd 302 5 speed tko
"THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!!
6772king is offline   Reply With Quote
Old 05-30-2005, 10:20 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here's a link to info on my swap in my K20, won't be any different than a K5. I had major issues, should have moved it all forward like 6772king.
454 swap info
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-30-2005, 07:30 PM   #4
Roberty
Hot Damn - Here I Am!!
Roberty's Avatar
Unless you go with a set of tall valve covers, I was under the impression that putting a big block in one of our trucks was fairly straightfoward - assuming that you use the big block engine towers. Are the people running into major clearence problems using the stock small block towers or something??
My vehicles:
'90 Silverado Sport
'71 Chevelle SS Convertible
'70 C-10 - My Grandfather bought it new - original un-restored
Roberty is offline   Reply With Quote
Old 05-30-2005, 08:15 PM   #5
Sweet72k5
Sweet72k5's Avatar
this is the big block iam putting in i have all the mounts for it and they are the tall valve covers but i can change them out to the smaller ones are plasma cut the fire wall to make it fit and redo some of the sheet metal on the fire wall but if i can avoid messing with the fire wall i will try not to mess with it..
Old 05-30-2005, 08:16 PM   #6
bobshotrodblazer
BigBlockBobby
If use the Big Block motor mounts you will have alot less hassle . You can use tall valve covers also. I put a 396 1n a 72 2wd blazer. I used shorty hedman chevelle headers .it worked out well.
Bob
bobshotrodblazer is offline   Reply With Quote
Old 05-30-2005, 08:18 PM   #7
Sweet72k5
Sweet72k5's Avatar
as well the motor thats in it now is a 327 and even with that motor the valve cover clear not by much but they are the tall valve covers for a small block..
Old 05-30-2005, 08:21 PM   #8
Sweet72k5
Sweet72k5's Avatar
very cool to now well will see how she goes going to start the trans plant next week and iam putting the 327 in my dirt track race car..
Old 05-30-2005, 09:15 PM   #9
orangeuavol
GO VOLS!
orangeuavol's Avatar
mine.
cut firewall for valve cover clearance.
http://pg.photos.yahoo.com/ph/jason_...28.jpg&.src=ph
http://pg.photos.yahoo.com/ph/jason_...38.jpg&.src=ph
http://pg.photos.yahoo.com/ph/jason_...42.jpg&.src=ph
http://1972blazer.shutterfly.com/<= blazer build pics
It's called golf because all the other four letter words were taken.
It's easier to ask for forgiveness than for permission.
orangeuavol is offline   Reply With Quote
Old 05-31-2005, 09:39 PM   #10
Big Bad 1972 Blazer
Big Bad 1972 Blazer's Avatar
Here's a pic of my 496 sitting in the engine bay . I've got it in the stock location and am running tall valve covers. I ran into MAJOR clearance issues with the firewall on both sides of the block...no mere dimples would have cured my problems. I cut out the interferance areas, created "pocks out of sheet metal and welded them back in. To give you an idea as to how much of an interferance I had...on the driver's side, I actually had to cut the hole for the clutch rod out. Fortuantely, I had to blow a new hole through the dash for the clutch set-up that I'm running...otherwise I'd really been S.O.L.!
Big Bad 1972 Blazer is offline   Reply With Quote
Old 06-01-2005, 12:18 PM   #11
Yukon Jack
Post Whore
Yukon Jack's Avatar
Big Bad 1972 Blazer - sounds like you had to make mods similar to mine.
My drivers side is still tighter than I would have wanted.
Old 06-01-2005, 02:42 PM   #12
Burt4x4
Burt4x4's Avatar
I put a 454 in my 72:
This last pic you can see were I had to BAM BAM on the firewall.
I also used a 73+ truck SBC crossmember to replace my factory 72 one. The two main reasons for this is, so I can remove the oil pan with out the Xmember being in the way and so I could use aftermarket SBC engine mounts for a more ridged mounting to the frame.
You can see the crossmember here:
I just got back from a weekend at Pismo Dunes with my K5....WOW I love 454 power. AWSOME!!! This engine ROCKED my K5 and it was so easy to climb the dunes...
Burt
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 06-02-2005, 02:57 PM   #13
shelby987
shelby987's Avatar
I came across a 1972 blazer in Texas that was for sale a little while back, the owner claimed that it was original.....is this correct? This thread makes me wonder....did the blazers ever come with big blocks (396 specifically) as a factory option?
Thanks,
shelby987 is offline   Reply With Quote
Old 06-02-2005, 03:03 PM   #14
Alexis
Member since 2000
Alexis's Avatar
Thanks,
nope
Alexis is offline   Reply With Quote
Old 06-02-2005, 09:52 PM   #15
Roberty
Roberty's Avatar
Thanks,
I would think that if it were a 2 wheel drive Blazer then it might have been but I'm not 100% sure on that. If it was a 4x4 Blazer then nope.
My vehicles:
'90 Silverado Sport
Old 06-03-2005, 08:34 AM   #16
shelby987
shelby987's Avatar
lol, kinda wondered about that.....he was asking for 8 grand for it.....and stated that if it were in original condition it would be worth double that (rust free body, but no top, roll bar, seats, and needed paint and other odds and ends). Thought I had found something rare.....guess the joke was on me.....but I didn't buy so....guess the joke could have been funnier!
Thanks,
Thread Tools
Display Modes
