Old 06-17-2002, 06:54 PM   #1
72ChevyCheyenne
72ChevyCheyenne's Avatar
Question Late Model Bed Swap
I know I seen one of the board members with a late model step side bed on theis truck. I think it was a 88 thru ?. I am planning on starting my tear down and resto in about a month and I really like the look. Can anyone tell what years the bed swap will work?
Bill Durham
http://home.attbi.com/~bulldurham
72 Cheyenne
Restoration in progress
Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed.
72ChevyCheyenne is offline   Reply With Quote
Old 06-17-2002, 09:01 PM   #2
lotik
drag it like you stole it
88-98
negative camber //LA\\
lotik is offline   Reply With Quote
Old 06-17-2002, 09:19 PM   #3
racedvl
racedvl's Avatar
The wheel openings are diffrent though.....
racedvl is offline   Reply With Quote
Old 06-17-2002, 09:21 PM   #4
lotik
which would be best to use then?
Old 06-17-2002, 09:31 PM   #5
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Thumbs up
If you really like the look and you have any welding skills, change one of the wheel openings to match. I've seen it done either way (rounded for the rear or squared for the front). Cut the section from the desired opening and and match and cut the undesired opening. Then weld into place. You can do some basic bodywork to blend it. Most people are afraid of bodywork but, if I can do it, anyone can. You can do it!
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 06-17-2002, 10:13 PM   #6
BIG ORANGE
BIG ORANGE's Avatar
Wink 90 model sportside bed
I got a nice 90 model bed for sale with zr1 rollpan and more upper S.C. $1.000 drop me a PM if your interested.
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Thread Tools
Display Modes
