Old 06-09-2005, 01:12 PM   #1
CHEVYE
my gas saver
CHEVYE's Avatar
Dumb ?... Brakes
i know this is gonna be a dumb ? but i'm not too informed on brakes . i just need to know how to tell which rotors i have for drop spindles? these year trucks seem to have a few different sizes. i assume you just measure the thickness but i'm not home now and wanted to make sure before i order them, thanks, eric.
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 06-09-2005, 01:25 PM   #2
bigblock73
yeller
bigblock73's Avatar
measure the width (thickness) of the rotor (the braking surface actually). You will have 1" or 1 1/4".
Easy enough?
I am pretty sure all trucks with the HD leaf packs out back got the thick rotors, but not positive. I am also not sure what criteria as far as options determines the rotor thickness. The only sure way is to measure IMO.
bigblock73 is offline   Reply With Quote
Old 06-09-2005, 01:43 PM   #3
CHEVYE
my gas saver
CHEVYE's Avatar
preeeeeciate it sir.
71`SWB, project
ebay feedback
Old 06-09-2005, 02:10 PM   #4
Eyegore
What Hump?
Eyegore's Avatar
Hey Jeff, doesn't the engine size also determine the width? For example those with the six cylinder and 305's had the 1" and the 350's on up had the 1-1/4". I noticed that my 86 w/ the 305 had the narroer while my son's 78 w/ the 350 had the wider. Does it work that way also taking into account engine swaps?
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 06-09-2005, 02:24 PM   #5
CHEVYE
my gas saver
CHEVYE's Avatar
hmmmmmm..... mine was orig. with a 305, i hope i don't have the small pnes. i need them to be large.
71`SWB, project
ebay feedback
Old 06-09-2005, 02:42 PM   #6
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Easy enough?
I have 1" rotors and heavy duty rear springs...
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 06-09-2005, 02:44 PM   #7
bigblock73
yeller
bigblock73's Avatar
Like I said guys, I wasn't exactly sure what dictated the thicker rotors.
I did say MEASURE though.
Old 06-09-2005, 05:11 PM   #8
86 GMG
imo i would say the older trucks hade 1 1/4 and newer had 1 inch this being changed when the trucks were lightened up a bit i believe this change took place in (81 ???)
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 06-09-2005, 11:49 PM   #9
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
My 84 Silverado (had factory 305) has hd rotors and 52in leafsprings 3 + overload with wider drums in the rear I forget the size on the drums.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 06-10-2005, 09:25 AM   #10
Turbo85GMC
Turbo85GMC's Avatar
Hypothetically Speaking
Just a hypothetical here......
Say I'm going to order drop spindles so I measure my current rotors and they are 1". If I were going to replace my rotors and calipers *anyway*, could I just order 1.25" dropped spindles and buy new matching brake rotors and calipers???
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
Old 06-10-2005, 11:42 AM   #11
CHEVYE
my gas saver
CHEVYE's Avatar
as long as the spindles are set up for 1.25" you should be able to change rotors/calipers. the spindles are the foundation and all brake sizes should stem from that.
71`SWB, project
ebay feedback
Old 06-10-2005, 03:51 PM   #12
MylilBowTie
Right turn Clyde
Don't forget about wheel bearings and seals, they more than likely need replaced and are different sizes stock vs HD rotors.
Thread Tools
Display Modes
