Old 06-17-2005, 03:03 PM   #1
cleszkie
cleszkie's Avatar
Mounting Auxillary Battery Tray
I just bought an auxillary battery tray for my 72 Blazer from another member of this board, but I can't figure out how to mount it on the core support on the drivers side. It is definitely a drivers side battery tray, as it doesn't match the tray I have on the passenger side, and it had the voltage regulator still bolted onto it. Are there more pieces required to mount it, or are the core supports for trucks with the auxillary tray different in some way? Or am I just not seeing something? Any advice or pictures of a mounted auxillary battery tray would be much appreciated. Thanks.
cleszkie is offline   Reply With Quote
Old 06-17-2005, 05:23 PM   #2
john
member #16
john's Avatar
I think it fits just like the pass. side except your support will not have the threaded nut inserts in it. You will need to weld some in or they make nut insert kits for jobs like this. Its been several years since I have seen one but I think that was how it was mounted. Good luck John
john is offline   Reply With Quote
Old 06-17-2005, 08:26 PM   #3
mocwon
Keep On Truckin'
mocwon's Avatar
Does anyone make these repo?
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 06-18-2005, 12:05 AM   #4
dtlilly
dtlilly's Avatar
No repop, gotta find an original, and not many left because not many were made, and it was an overlooked part for many years.
dtlilly is offline   Reply With Quote
Old 06-18-2005, 01:05 PM   #5
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
My camera got swiped at a school function or I'd take a quick pic. I'll describe it the best I can.
Outboard side: upper and lower uses nut plates attached to the tray. Bolt from front to back. Upper bolt hole is just below the radiator support corner brace above the headlight cut-out. Lower bolt hole is in the raised area below the healight cut-out. Think the middle hole was used for grounds, it does not contact the radiator support.
Inboard side: Upper and lower uses nuts and bolts. Bolt from back to front. Upper and lower bolt holes should be obvious. Middle hole not drilled on my factory optioned truck.
Once installed the outboard rear corner of the tray will rest about an 1"- 1"1/4 above the wheel well.
Hope this helps.
Rich
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 06-18-2005, 01:11 PM   #6
Jimmy72custom
Jimmy72custom's Avatar
I bought a universal battery tray and cut up an old rusted out passenger side tray. Cut, reversed and welded the mounts a little and wa la (wa la?) an auxiliary driver side tray.
Jimmy72custom is offline   Reply With Quote
Old 06-18-2005, 02:20 PM   #7
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
This is just a top shot but it shows you where it goes. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-18-2005, 03:25 PM   #8
ericguy320
where dose that relay mount to, mine was just hanging there. Also where can i get one the one I have is burnt
http://community.webshots.com/user/ericguy320
1972 Chevy C10 SOLD
1972 k5 blazer cst 350, sm465, rust
1993 gmc Typhoon for sale $13,900 obo
1980 Ironhead Sportster
ericguy320 is offline   Reply With Quote
Old 06-18-2005, 07:52 PM   #9
mocwon
Keep On Truckin'
mocwon's Avatar
That won't work for me...
Thanks for the pictures guys. After seeing these, I'll need to just fab a tray or use one out of a later model vehicle. I mounted the electric fan controls on that vertical rail next to the radiator
Just Passin' Thru
Old 06-18-2005, 10:54 PM   #10
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Battery tray mounting...
GM usually engineers all options into things, later years may have things earlier years wont because an option wasnt available when , for example, a core support was stamped.
On most of my findings with GM sheetmetal, there will be stamped "tits" into the core support where an assembly worker could find the location to drill holes for otions ordered. There may likely be this on your core support in that area if your core support is the correct year item for which you are mounting this battery tray on...
Take a look and see if you have this...
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 06-20-2005, 07:12 PM   #11
cleszkie
cleszkie's Avatar
Thanks for all the replies!
Wes and Chickenwing - The description and pics are worth their weight in gold. Thanks.
Jimmy72Custom - I applaud your ingenuity on that tray.
To answer someones question, it is an original auxillary battery tray that I bought from CSTHugger off this board. It was an excellent piece at a good, fair price in my opinion. I do not believe that these trays are being repoped at this time. BTW, CSTHugger is very good to deal with when buying parts.
Old 06-20-2005, 10:05 PM   #12
hotrodmtodd
'Burban Legend
hotrodmtodd's Avatar
I Just Bought One For $5
Did not realize they are so rare. I just bought because I thought it was cool. It is in VERY nice shape. I have a Camper Special, so I thought it might come in handy some day. If someone is DESPERATE for one I would let them have this one. Or if someone wants to use this one for a pattern to fab one, that would be OK too. Take care, Hot Rod
'67 Chevy Iron City Beer Truck (9ft step)
'67 Chevy Panel Truck 467
'68 Short Fleet 305v6
'68 McLaren Ramp Truck
'68/'68/'70/'71 Burbs 292/366/402/454
'69 C-30 dump
'71 C-50 dump and church bus
'71 4x4 454
'72 Blazer (w/pop-up camper) $15 x-hooks
'66 Chevy II 194/Weber
'68 El Camino" 305v6
'69 Skylark 455 Buick
'70 Chevelle 427
'71 Cutlass W-31
'71 GTO 400 2x2
"The 51" Chopped '51 Chevy (409) my first car
OK Toad, we'll take 'em all... John Milner
hotrodmtodd is offline   Reply With Quote
Thread Tools
Display Modes
