Old 06-24-2005, 12:22 PM   #1
Shev
Head Peon
Shev's Avatar
Is 8" Notch big enough?
To lay frame on my '88 burb with a 30" tire...or should I go with a 10"? I did some simple measuring (frame is 8" of ground right now, axle tube is 2" from touching the frame) drew it up quick in CAD and it seems like I should have 1" clearance to the top inside of the notch. Anybody have any input?
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4
Shev is offline   Reply With Quote
Old 06-24-2005, 12:50 PM   #2
fastbagged68
fastbagged68's Avatar
Sounds about right! When or if you lift the front first then a 10 inch notch will give you room to go lower in the rear. If you run a 8 inch the rearend will hit the notch if the front goes up first. Make Sense....
fastbagged68 is offline   Reply With Quote
Old 06-24-2005, 01:37 PM   #3
Shev
Head Peon
Shev's Avatar
Thanx Fast, I was only thinking of laying...I think I'll go with 10" just to be safe and I think that will give me the option of putting my F9000's over the axle if the need arises.
Old 06-24-2005, 08:00 PM   #4
slammd72
slammd72's Avatar
shev... are talking 10" from the bottom of the current frame to the bottom of the notch? ive got an 88 cc dually in need of a notch and bags as well.
also is your burb 3/4 ton? how far does your frame hang below your rocker pinch weld?
88 shortbed crewcab
currently getting a sfbd 4 1/4"
slammd72 is offline   Reply With Quote
Thread Tools
Display Modes
