Chevy Forever
Read almost everything still have questions
I know it is a Novella but if you could please read it I need some more help Thank you.
Ok I have been reading the posts here for about 4 days now since I found it and saw the wealth of knowledge that is freely given out here. It took a long time to surf through the all those pages since there isn't a search function now. It is nice to see a site dedicated to my favorite trucks here is what I have and what I need. I have a 1971 C20 with coil springs on all four corners and disk brakes upfront. I have it down to the frame at this point and I figure I am building it back up might as well make it like I want it the first time. So I have decided that a AirBag setup will be my best bet for being able to have the adjusability to haul a trailer but bring it down when I want I am not looking to lay frame or rockers just get it much lower then the stock ride hieght I really like how Primered thunders truck looks but I will be putting drop spindels in so I can run a little more air and make the alignment angles a little better as you guys here have recommended in the past on the board. Now here are some questions for all you out there that are a lot smarter then me I know there will be some challenges with the 3/4 since I want to keep it 3/4 ton. I need to know since I can't find a adjustable panhard bar that says it is for a 3/4 ton will a 1/2 ton work. Also I have talked to the guys at GMC Pauls today but I was left a little confused I have read here on numerous times that the only drop spindels out there for 3/4 ton are the ones that need the ball joints and outer tie rods from a 73 to what ever year. Is this not the case with the ones from GMC Pauls. I also need to know is there any clearance issue with SS Rs 72 on the front of rear of these trucks I know that I will need to shave off the bump stops on the lower control arms but other then that is there anything I need to know. I have a line on a ride po air managment kit from Innovative air suspension that I will be using for my tank and compressor but my question is if I plumb this system will I need a second compressor and tank. Now I don't plan on jumping of bouncing this truck. so will a single 3 gallon and the compressor that comes with the kit do the job? (kti is ARC4000E) Please let me know if I am way off base with this and if I am please point me in the right direction thank you all in advance. |
'70 GMC C-25 LWB
Welcome. I also have a 3/4 ton but mine a 70. As for the rear I know nothing but up front I have 3/4 ton drop spindles from gmc pauls and you do need the 73-87 tie rod end ends and balljoints uppers and lowers I dont know if your brakes will work but i do know 73-87 will, as far as I know these spindle will keep the 3/4 ton. Hope this helps.
1970 GMC C-25 LWB (middle of frame up) 5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood. 1987 Camaro z28 350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer. 1988 Monte Carlo (Super Stock ashpalt race car) My Truck |
Chevy Forever
I will have to get with GMC Pauls again becuase he was telling me that I woudn't need anything else maybe something is diffrent on the 71-72 models. Thank you for the information. The biggest thing is keeping th 3/4 ton I have plans on purchasing a enclosed trailer to haul the wife's 69 chevelle SS so I need some thing that will pull it plus really don't want to deal with swapping out my rear and front end to go to 1/2 ton.
On the 3/4 ton trucks, the spindles & ball joints/ tierods are the same from 71-87......the 1/2 ton trucks do have 71/72 by themselves, then 73-87
http://community.webshots.com/user/hotrodhorn |
Chevy Forever
Thank you for the information CrazyL Now all I need to know are the adjustable panhard bars for the 1/2 tons going to work on my 3/4 ton in the stock location. I think they look the same but would like to hear from the experts
Chevy Forever
still need info on panhard bar anyone out there know?
My first love 1971 C20 Hugger orange Getting face lift and heart transplant .30 402 BB /TH400 and GV Wifes car 1969 Chevelle SS 396 325hp/TH400 Factroy A/C Automatic w/ Floor shift console. restored. |
Thread Tools | |
Display Modes | |
