Old 07-10-2005, 12:43 PM   #1
cosmicbrat
Clicking from a front wheel...??
1984 1500 classic GMC PU... Sometimes front driver wheel sounds like a beerbottlecap is stuck to tire after 60km... Have wheel off, but can't find why the clicking... Any ideas out there?
AND, If I changed the 4-brl carb on 305, to a 2-brl, what would it do for gas millage? I don't need the V8 power, and I pretty much stay at 75 to 80Km on the highways... I drive slow safe and easy... [It used to be 0 or 80mph, till I slowed down, to discover that there are trees, buildings, and people in that green-blurr... and there's less chances of killing innocent critters on the road this way..]
What other vehicles carry those 2-brl carbs that look like a 4-brl?...
cosmicbrat is offline   Reply With Quote
Old 07-10-2005, 02:55 PM   #2
71swb4x4
71swb4x4's Avatar
On the clicking, I had this problem once. I pulled the center cap and there was a rock in it. Put it back on, no more clicking. Since yours is at speed, I wouldn't think it would be a rock, the rock will quit clicking once you hit 15 - 20 mph. But, you may want to check that out just to be sure.
On the 2brl, if you stay out of the throttle anyway then the 2brl may not help much at all. If you are always into your throttle opening up those other 2 then the 2brl will help a bit. Basically don't be aggressive with the go peddle, and it will be like you have a 2brl anyway.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-10-2005, 05:46 PM   #3
cosmicbrat
"don't be aggressive with the go peddle, and it will be like you have a 2brl anyway."
I drive like a gentleman grandpaw farmer... *********************... I respect the metal in my precious truck... I haven't spun those tires even once in the two years I've had the truck...
It feels like the 4-brl's click-in at 45 mph... Is there a way to make it so the 4 brl's don't click in till 55mph?...
What's your opinion on those tv advertised, aluminum fins, airflow shaper, turbo inserts, that you shove into the engine's air-intake?... I'm thinking on making a set for the truck...
I was told that occassional popping out of the carb, means that the cam is wearing out, and it's crushing lifters... and when it progresses to three cam knobs, the engine will barely start... What do you know on that?...
******Edited by Tx Firefighter to remove unacceptable phrase******
Old 07-17-2005, 04:16 AM   #4
c-1072
Clicking
What the clicking probably is : check the outer brake pad there are two tabs that go around the caliper . Take a screwdriver pry up on the pad between the rotor and pad and bend the tabs down with a hammer .
c-1072 is offline   Reply With Quote
Old 07-17-2005, 11:37 AM   #5
SCOTI
SCOTI's Avatar
I agree. Take the truck for a drive (somewhere w/o a lot of traffic since your focus won't be completely on the road!). W/the window down, (so you can listen closely), slowly drive alongside a long curb & see if you hear the 'clicking' noise. Once you hear it, lightly press on the brake pedal & see if it goes away. If it does, more than likely it's the caliper/pad shifting around.
Bend the tabs as far as you can w/a small hammer to tighten everything up. Repeat the test-drive scenario & see if it worked.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-17-2005, 12:43 PM   #6
cosmicbrat
Thanks! I'm on it!...
Thread Tools
Display Modes
