Old 07-12-2005, 01:49 PM   #1
Beefcake
72 3/4 GMC camper special lift.
hey guys.
I would like to lift my 2wd camper special - just in the front. The rear has like 9 leafs on each side... (I believe from the factory??"... so Im basically wanting to level it out.
I was wondering if I just swapped the springs (in the front) for 3/4 ton big block springs if this would give me the extra 2 or three inches Im looking for....
what do you guys thinK? would it make the ride to bouncy??
72 GMC Camper Special 2500.
currently has 350/350/14 bolt. 383 and 400 tranny is in the works.
Beefcake is offline   Reply With Quote
Old 07-12-2005, 03:11 PM   #2
Beefcake
another question- can I use the same control arms w/ big block springs??
Old 07-12-2005, 11:30 PM   #3
BobS
BobS's Avatar
It may already have the equivalent of Big Block springs in the front if it came from the factory as a Camper Special. 1-ton springs may help a little but I don't think you'll get quite as much lift as you're looking for but maybe it will be enough to make it look a little more balanced. The control arms should work fine with the heavier springs, at least I know the big block springs will, I've never swapped 1-ton springs into anything.....yet.
Bob
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 07-13-2005, 07:56 AM   #4
Beefcake
Hmm... I dont know of any 2wd lift kits for a 72.....
thanks for you responce bob
anybody else have any advice here??
Old 07-15-2005, 06:17 AM   #5
pooz911
pooz911's Avatar
I'm sorry, is the camper special a BB or a SB?? I have a 1971 custom deluxe 20 w/ a sb 383 crate motor. I installed rancho springs for a 1973-1987 chevy truck. (basically its the same as bb springs) The front suspension was riding at the upper bump stop with virtually no rebound. I have since removed the stock bump stop, installed a shorter one, added a upper ball joint spacer and mounted the upper ball joint under the uca. Now I have about 2 inches of rebound. My dad has a 1972 chevy 3/4 ton w/ a BB chevy. He has 1 ton springs in the front and sits 1-2 inches lower than I do.
pooz911 is offline   Reply With Quote
Old 07-18-2005, 12:21 PM   #6
Beefcake
sb.. 350/stock.
I didnt know I could swap w/ parts up to 87... If I can do that, I could probley find a lift package easy...
Old 08-15-2005, 06:43 PM   #7
aquik72gmc350
You can use 73-87 Suspension items on 67-72 Trucks but you must do as following:
Must use:
Upper and Lower Control Arms 73-87
Shafts must use from 73-87
Spindles from 73-87
Ball joints must match Spindles
Must use outter tie rod from 73-87
Must use inner tie rod from 67-72
I'm in the process of Building a different front end for my 72 GMC C-1500. I'm using the above items on a 73-87 crossmember with all new Moog parts, 3'' lift Springs from FabTech, all new Disc brake items, and braided brake lines. I have part #'s from the items I'm using if you want them.
aquik72gmc350 is offline   Reply With Quote
Thread Tools
Display Modes
