Old 07-13-2005, 10:13 PM   #1
SanitysBane
AirBag Damage?
Hey guys, I was looking around at some kits and I was thinking, does it hurt the bag any for it to not be straight when its air up? Like will it create a weak spot in the bag or anything if the bag at normal ride height is like the cantelever set up and gotta a bend in the middle or is it better for the bag to be straight up and down like the bar?
Thanks.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 07-13-2005, 10:15 PM   #2
XXL
Seņor Member
XXL's Avatar
Hurt? Not really. Ideal? No.
XXL is offline   Reply With Quote
Old 07-13-2005, 10:16 PM   #3
SanitysBane
Thats what I was thinking, thanks XXL.
'88 K5 Blazer
Old 07-13-2005, 11:54 PM   #4
1STtimePRo'71
1STtimePRo'71's Avatar
The grain trailer that hooks up to my International has a setup like the one in the right picture. Though the bags are bigger it's the same concept. Can't see why it would hurt anything.
-Cory
1967 2 Wheel Chevy
1STtimePRo'71 is offline   Reply With Quote
Old 07-14-2005, 08:58 AM   #5
XXL
Seņor Member
XXL's Avatar
BTW, the actual suspension setup (reverse 2-link) is not a particularly good idea.
Old 07-14-2005, 01:39 PM   #6
fastbagged68
fastbagged68's Avatar
When you mount bags on any arm front end the bag will not be square at all time! You try and make it square at ride height when possible.
fastbagged68 is offline   Reply With Quote
Old 07-14-2005, 04:27 PM   #7
Izzy
Trucker.
Izzy's Avatar
That's a KP 6 link, it's a perfect setup to run if you have the $$. You can't see the forward parallel link.
Izzy is offline   Reply With Quote
Old 07-14-2005, 06:15 PM   #8
SanitysBane
I think I am going to make my own brackets, I don't like that cantalever set up and the bags beging like that. THanks alot guys.
'88 K5 Blazer
Old 07-14-2005, 06:45 PM   #9
fastbagged68
That pic of the KP Components Canti set up is at full lift. Look at the difference between the bottom of the notch and axle tubes. If you plan on getting a lot of lift plan on having your bag do the same thing as it does it that pic. If you plan on keeping the bag square through it's whole cycle from collapsed to extended plan on only getting the manufacture specs out of it.
Example- F9000- min height 4.5", max height 12" Only going to get a 7.5" of lift. Not that much.
KP Components- with a double convulate bag F6873= 2600# bag Min height 3", Max Height 8"- 5 inch lift......but with the KP canti expect 10-12"
Hope this makes sense.
Old 07-14-2005, 08:12 PM   #10
Izzy
Trucker.
Izzy's Avatar
You should see the bind the rear bushing of the canti bar gets at full lift, it's crazy.
Old 07-14-2005, 10:36 PM   #11
KdawgS10
keller
KdawgS10's Avatar
yea this isent even a bad angle. have you even seen bags in a front set up at full lift. they look like thier gona pop out the side of the Aarms thier so sideways.
double conveluted bags are made for lifing at angles like that. only bags you cant run like that are sleave bags and triple conveluted.
83 1ton 4door dually, 350/700r4
99 S10 2.2/5speed bagged. traded for the dually
91 S10, 2.5/5speed juiced
87 3/4 4x4, 350/4speed
89 S10 long bed , 2.8/5speed
65 chevy short bed stepside, 327/3speed
97 neon acr, 2.0 dohc 5speed DD
KdawgS10 is offline   Reply With Quote
Thread Tools
Display Modes
