Old 07-18-2005, 02:26 AM   #1
c10rookie
c10rookie's Avatar
72 C10 advice wanted
Hi guys, I have finally cured my motor woes and the truck now rolls very nicely, I now find that I will be needing to up-grade my suspension as it gets a little skecthy especially over holes and raised ironwork
It has been dropped 3" front and 5" rear, I beleive the front to be on axle and spring mods, the rear is just spring.
The truck seems to deflect or skitter over the road after a hit, the dampers seem OK and not to springy ?
My question is how can I improve my ride quality without having to get a BIG overdraft, can springs and dampers solve it or shoud I get more up to date equipment under it like air ? Truck is my sunday ride only.
if it aint broke , fix it till it is
355- flat tops - 70cc RPM heads 9.5:1
RPM inlet MSD6 & HEI
headmans & glasspacks
Crane .467/.494 278/290 222/234 114
1.6 roller's 2400 tci 650 Holley
cold air induction electric w/pump,fans,f/pump
c10rookie is offline   Reply With Quote
Old 07-18-2005, 09:27 PM   #2
slammd72
slammd72's Avatar
I Dont Know about everyone else, but the reason i am going to air is to lay out and not for ride quality. but the ride quality is better then the stock suspension was on my truck.
i think first thing you should do is shocks? they arent that expensive and that would narrow down what is causing your loopyness! IMO
slammd72 is offline   Reply With Quote
Thread Tools
Display Modes
