Old 07-23-2005, 03:25 AM   #1
68xxx
Found alignment problem!
Hi Guys,
I finaly found out why I can't get my camber set right.
It appears that I have one incorrect lower control arm and it is about 1/2 an inch shorter than the other one thus the reason I cant get enough adjustment out of the shim setting and thus why the wheel is too far inward at the bottom of the wheel.
The one that I am having problems with is the passenger side and it is different in several ways. There is more steel overhang at the shaft end, the "lip" is different and the bumpstop area is also different. The main difference is of course the length.
I used the shaft zerk fitting and the inside edge of the tire for reference.
Have a look at the pics and see if you can tell me what this control arm is from.
I intend on replacing the control arm but would like your comments.
Thanks, Mark.
68xxx is offline   Reply With Quote
Old 07-24-2005, 11:10 PM   #2
FirstGen
Just Don't Stop!
FirstGen's Avatar
One is off a 3/4 quarter ton truck and one is a half ton. The longer is the 3/4 ton lower a-arm.
Take care.
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 07-25-2005, 04:01 AM   #3
cowboy33713
Howdy;
I'm not sure- my 1/2 ton 67 has the long style on both sides. Just finished up a front end rebuild of my own. Had to replace the badly damaged passenger side lower arm, and the fella a bought from sent me another one of the same . \
Oh well. It works!
cowboy33713
cowboy33713 is offline   Reply With Quote
Old 07-25-2005, 04:37 AM   #4
68xxx
Thanks guys,
I would need to replace the passenger side with a longer arm in order to give me the needed amount of adjustment.
I'm a bit worried as I have to order the parts in from the USA and freight will kill me so I want to make sure that I am ordering the correct one and as I believe that the ball joints are different for the 1/2 and 3/4 arms I will have to get it as well.
So looking at my pics do you both agree that the passenger side (left side looking from front of truck) is currently a short 1/2 ton arm.
Thanks for your help, Mark.
Old 07-25-2005, 09:55 AM   #5
FirstGen
Just Don't Stop!
FirstGen's Avatar
That's what it looks like to me. Give Ed at MotherTruckers a call, he is a board sponser and he will have either 3/4 ton or 1/2 lower a-arms used to sell you. He could probably also confirm that what I think is correct since he does that stuff more often. Post up what you found out.
Later.
TT LSA/6L90e/9"
Old 07-28-2005, 02:48 AM   #6
68xxx
I emailed muther truckers but as yet have not received a reply. I looked at a C20 yesterday and it had the longer arms so I'm sure that they are what I need. I will pursue a supplier for one of those. I'll repost once I have this sorted.
Thanks for the help.
Mark.
Old 07-28-2005, 08:54 AM   #7
Joe67
67 is sold
Damn, glad you spotted that
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 07-28-2005, 05:16 PM   #8
69 longhorn
Im not sure what the problem is.....? I will say for sure that you can not mix 1/2 & 3/4 ton lower arms tho! The balljoints are different in the OD that presses into the arm......I swapped my 3/4 to 1/2 ton suspension. the 3/4 top arms will bolt the 1/2 ton balljoint......but the lower arms had to be swapped, to get the 1/2ton balljoints to fit I wonder if somebody replaced 1 of the arms with a van arm at 1 time......? 69L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 07-30-2005, 08:43 PM   #9
68xxx
So is there another spanner in the works?
Are the Van arms different from the truck arms?
So far it seems that there are the 2 different lower arms for the 1/2 and 3/4 ton trucks but is there more possibilities???
I have to have an arm shipped to the other side of the planet so I want to get it right!!!!!
Mark.
Old 07-31-2005, 01:44 AM   #10
FirstGen
Just Don't Stop!
FirstGen's Avatar
nope 3/4 or 1/2 ton that's it. Call MotherTruckers and he will hook you up...
TT LSA/6L90e/9"
Old 07-31-2005, 11:21 AM   #11
69 longhorn
Mark.
Just thinkin outloud there.... I dont know what the prob is, but there is NO WAY IN HE!! that you can mix balljoints in 1/2 & 3/4 truck lower a arms.....unless somebody made a press ring , to resize the hole in the arm for the balljoint. The hole for the balljoint is smaller in the 1/2ton arm Is the truck a 1/2, or 3/4 ton? 69L
Old 07-31-2005, 01:29 PM   #12
FirstGen
Just Don't Stop!
FirstGen's Avatar
correct, but you can use the correct ball joints in the same spindle...
TT LSA/6L90e/9"
Old 07-31-2005, 05:29 PM   #13
69 longhorn
The spindles also take different balljoints going from 1/2 to 3/4 ton.....the parts flat dont mix without some mods(re machining the ball joint holes in the spindles, or welding rings in the hole in the a arm). Unless I am missing something on the yrs of the parts.......71-72 absolutely have different spindles, lower a arms, & balljoint assys when swapping from 1/2 to 3/4ton. The 67-70 arms will also work, by swapping the balljoint & tierod assys(for the disc brakes). The 73- 87 spindles will also work the early arms......but once again , you need to use the proper balljoints, spindles & lower arms to make the swap. 1/2 ton balljoints do not fit 3/4 ton lower arms, & vice versa.........crazyL
Old 07-31-2005, 07:46 PM   #14
FirstGen
Just Don't Stop!
FirstGen's Avatar
I guess your right. I was thinking that you could use either on the drum brake spindles... I know for sure that I used the 1990 lower ball joints on the 3/4 spindles...
No telling.
TT LSA/6L90e/9"
Old 07-31-2005, 10:43 PM   #15
69 longhorn
FirstGen, it obvious that that the pass side arm doesnt belong on that truck......I cant say for sure what it belongs on tho! On the early (67-72) 1/2tons, they had the steel bushings in the arms. 73-87 1/2 ton trucks went rubber on the bushings, where the 3/4 ton trucks still had the steel bushings. Im guessing(for lack of other info) that is a '68 1/2 ton truck pictured? I have 1/2 ton bottom arms(71 pcs) on my 69 longhorn , & they dont have that extra steel past the ends of the bushings......the orig 3/4 ton arms didnt either tho! On a stamped steel pc, the extra material doesnt mean much.......but I do see that there is a diff in measure from cenetr to center 68XXX......can you put in some more info on the truck? what yr, 1/2 or 3/4 ton,what swap spindles, ect? 69L, still confussed.....but its just a way of life
Old 07-31-2005, 11:31 PM   #16
FirstGen
Just Don't Stop!
FirstGen's Avatar
haha, we may never know!
TT LSA/6L90e/9"
Old 08-01-2005, 05:29 AM   #17
68xxx
Wow at least we are getting some interesting disscussion here!
OK, my truck is a 68 short wheel base fleetside so I'm presuming that it is a half ton truck. (see pic).
It is fitted with Early Classic dropped spindles and disc brakes (believed to be stock later model).
I bought the truck this way so don't have much more info.
The unusual thing that has been identified by earlier posts is that my truck has very few adjusting shims and earlier replies indicate that aparently when lowering a truck there is usualy a large number of shims needed to get the camber right.
So does this make anything clearer????
Mark.
Old 08-01-2005, 01:04 PM   #18
69 longhorn
I think you just need another rh lower a arm to fit your 68 chevy 1/2 ton. you have a couple different options on the lower balljoint(depending on the spindle used). 71-72, & 73-87 with the thick rotor(1.250) take the same lower ball joint. There is a dropped spindle available to fit the 67-70 trucks, that accepts the original balljoints & tierod ends. if you can ID the spindle, it will help with balljoint selection. Best of luck......69L Nice truck!
Thread Tools
Display Modes
